Old 10-04-2012, 08:05 PM   #1
tehcbass
My Ride: bmw e46 323i
Coolant getting drained quick
hey guys
i recently got the collant yellow light on my 323i so i checked it, and t was completely drained!
i wasted half the coolant bottle filling it.
this was yesterday.
today i checked it again and it wasnt drained all the way but it lost about 1/4 gallon of coolant.
so i filled it.
i also have white spots around the coolant cap.. appear to be spills of some sort.
does anyone have an idea of what the cause might be?
i searched it up and so far i have (water pump, radiator, thermostat, or hoses)
thanks
Long Nights and Sandy Beaches
tehcbass is offline   Reply With Quote
Old 10-05-2012, 07:55 AM   #2
LlamaGoat
My Ride: 330d e46 touring
Sounds like head gasket with loosing coolant, unless there is an obvious leak somewhere in the pipework??
LlamaGoat is offline   Reply With Quote
Old 10-05-2012, 01:41 PM   #3
Matheeuwissen
My Ride: BMW 323CI
Maybe your expansion tank is leaking. Sometimes it wil break and leak. first tiny bits, but it will be worse.
Matheeuwissen is offline   Reply With Quote
Old 10-05-2012, 01:46 PM   #4
ModBargains III
ModBargains III's Avatar
My Ride: E46
White spots on the expansion tank means you're leaking coolant at the top once the heat and pressure gets up to the top... Not a head gasket issue, just an issue with leaking at the cap, or somewhere else around that area.
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 10-05-2012, 03:37 PM   #5
tehcbass
yea but the spots on the top arent the things that are worrying me..
im losing 1/4 of a gallong of coolant a day...
most people are saying its my expansion tank...
how do i check if its that and if it is, is it easy to replace and shiet?
Old 10-05-2012, 03:45 PM   #6
briangl92
My Ride: VQ37VHR
Check your expansion tank cap. I got a defective one that didn't seal properly and it caused me to lose coolant out the cap. New cap solved that issue. I also got my car back from the dealership yesterday and they didn't bother to tighten the cap all the way down. I lost 3/8ths a gallon with the cap being loose over a 20 mile drive. It left white coolant residue everywhere including on the expansion tank.
briangl92 is offline   Reply With Quote
Old 10-05-2012, 03:49 PM   #7
tehcbass
so the cap has to be reallllyyy tight?
like, i cant close it with just my hand?
Old 10-05-2012, 03:54 PM   #8
briangl92
My Ride: VQ37VHR
You can tighten it by hand. It needs to be tight but nothing crazy. The dealership only had the threads started and it was loose. If you're leaking coolant from your cap (whether the cap is defective or loose) there'll be coolant on the threads of the tank.
Old 10-05-2012, 04:13 PM   #9
tehcbass
ohh alright thank you bro, im gunna go check it now see whats up
Old 10-05-2012, 05:29 PM   #10
Matheeuwissen
My Ride: BMW 323CI
I don't think your cap is not tight closed enough.
Maybe you can put some little pressure on the cooling system, probabely around 1 bar.
You can easily see it when the expansion tank is leaking, because the water will tear out of it.
Old 10-05-2012, 06:13 PM   #11
tehcbass
im not familiar with this, 1 bar, you speak of
Old 10-06-2012, 04:10 AM   #12
Matheeuwissen
My Ride: BMW 323CI
about 14,5 PSI.
just to set straight you don't put to much pressure on the system to test for leak, otherwise hoses wil burst or you waterpump will start leaking.
Just put a little pressure on to the system.
Old 10-10-2012, 09:04 PM   #13
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
He is saying to pressurize the cooling system to 1bar(14.5psi). there are tools for this.
www.E46Turbo330Ci.com
WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo
The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter
NIVO is offline   Reply With Quote
