Old 10-27-2012, 12:54 PM   #1
willsbma
My Ride: 99 323i
Question Water pump/expansion tank dilemma
I was trying to search around but I'm not sure of what to search for.
Under normal operation the fill neck of the expansion tank has a small little hole that pisses coolant into the tank. I've observed this many times. Now if coolant does not piss from that little hole, does that mean the water pump is bad? My radiator is hot at the top and cold along the bottom which means either air pockets or no flow. Def no air in the system. My water pump is aftermarket with metal impeller but isn't weeping or making any noise. I might just pull it/replace anyway to be sure but I wanted some opinions. TIA fellas
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 10-27-2012, 01:58 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
First, lets start with the 'def no air in system' because there may be and you might not know it.
If you have a small leak somewhere and air gets into system, wp could cavitate when it swallows bubble and not pump.
That said, the coolant goes into top of radiator hot and should come out cooler from the bottom hose.
I never open mine up when it's running, so don't know if that little stream is diagnostic or not.
Maybe start with my 'alternative bleeding' method? Search me, 4K rpms, and 20 secs. I've written instructions a hundred times...should be easy to find. Give that a shot...and confirm that you're not leaking/seeping coolant.
Keep eT filled only to between min and max...don't overfill--I'm sure you know this.
...and a bump for you!
HTH
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-27-2012, 02:09 PM   #3
///MPR77
My Ride: 02 ///M3 Tri-Ped
HTH
+1
I do this as well...get the car just warm enough to build some pressure. Then proceed with proper bleeding.
When the process is complete, you will need to remove excess coolant from et.
I believe it took about 5 normal size turkey basters to get it to the proper level on mine.
And damned if I didn't have to do it a couple of times.
So don't assume def no air in the system quite yet.
Old 10-27-2012, 02:17 PM   #4
willsbma
My Ride: 99 323i
I should have mentioned i did the 4k 20 sec bleed too. I just finished replacing everything so im 99.9% pos of no leaks or air. Im gonna pull the belt and feel the pump now. If it feels funny at all im ripping it out.
Sent from my DROIDX using Bimmer App
Old 10-27-2012, 02:35 PM   #5
willsbma
My Ride: 99 323i
I just pulled the pump, the impeller was totally disconnected from the pump shaft and circulating no water. Figures...New w/p will be installed shortly.
Old 10-27-2012, 03:12 PM   #6
dmax
dmax's Avatar
Very nice you found it so quickly.
One thing you didn't mention in your first post was whether you were overheating or not. I'm presuming that maybe you noticed something...IDK.
Without wp circulating, your temp sensor on lower hose wouldn't raise the temp gauge, so I hope you hadn't been driving too far before you noticed this. I doubt it. There are other temp sensors that would probably have noticed something amiss...like oil temp sensor...so hope that's all it was.
Impressive you found it so quickly...glad you didn't mess around!
GL! (Oh, give us age and brand of that WP so we know to avoid it please!)
Mangofy your E46!
Old 10-27-2012, 08:20 PM   #7
willsbma
My Ride: 99 323i
Yea im glad i caught it fast too. I should have known earlier when the heat stopped working but ive been stressed and not really dedicated lately. I was mistaken when i said it was an upgraded metal impeller, it was not. I did however use metal this time. It's a brand new bosch for $50 from pep boys. I just did a leak down test and all the cylinders were within 20% so im pretty sure the motor is healthy still.
Old 10-27-2012, 10:03 PM   #8
Stinger9
My Ride: '04 330Ci
That's why I'm so comfortable with my Stewart pump.
Totally personal decision.
Old 10-27-2012, 10:40 PM   #9
willsbma
My Ride: 99 323i
I've read a lot about the stewart pump and from what I've researched it seems that it's not worth the money. To each his own I guess.
