Old 10-12-2012, 06:19 PM   #21
always-there
My Ride: 2002 BMW 330I
Got the car back on the road. It had a lotta air.
Old 10-12-2012, 06:22 PM   #22
jhaurimn
My Ride: 01' 330ci
Bleed the system . Drive the front on 2x4s to help the air out the bleed valve. Turn heat on highest temp and lowest fan speed (don't start car) and unscrew the bleed valve until coolant starts to come out. Have towels ready to avoid making a mess. Look to see if there is any air bubbles in the coolant, if there is none , screw the bleed valve back on . DO NOT OVER TIGHTEN THE BLEED SCREW . Very easy to strip this !! Then top off coolant to correct level. Now start car, unscrew bleed screw just a little to make double sure the air is out. Now go drive around until it gets to operating temp. Then allow car to cool fully. Then top off coolant.
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 10-12-2012, 06:23 PM   #23
jhaurimn
My Ride: 01' 330ci
Well at least you fixed it... Too bad I typed that all on my phone for nothing
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 10-12-2012, 06:23 PM   #24
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Btw, Behr and Sachs are the OEM brands for fan clutches. How much did you spend on the new one?
Old 10-12-2012, 06:34 PM   #25
always-there
I just bled it again, it's fixed. Freaked me out -_- What's funny is that I just replaced the water pump thinking that would solve the loud fan noise and it did, but I can still hear a faint fan noise. Could this be the aux fan doing that?
Old 10-12-2012, 07:14 PM   #26
always-there
I don't think I said that correctly, lol. I replaced the water pumpand fan clutch thinking either would solve the loud fan noise, but nope. As soon as I drove it after replacing the water pump it was completely gone, and after the overheat it came right back. If you guys have any idea what it could be it would be appreciated.
Old 10-12-2012, 07:15 PM   #27
Solidjake
Zero. Leaks.
Solidjake's Avatar
So how much did you pay?
Old 10-12-2012, 07:16 PM   #28
always-there
I spent around 68 I believe? I bought the meyle brand on bma parts.
Old 10-12-2012, 07:18 PM   #29
always-there
Jhau, you didn't waste your time. You certainly gave me self assurance and pointed me the right way. Sheesh, the cooling system on this car is picky.
Thanks jhau !
Old 10-12-2012, 07:21 PM   #30
Solidjake
Zero. Leaks.
Solidjake's Avatar
Could have added $120 more and done an electric fan swap.
More power, better acceleration, no damage to your hood/belts/etc, easy to take the fan out to work on the car, weight reduction, better mpg, etc.
Old 10-12-2012, 07:24 PM   #31
always-there
I see..although, I really want to fix sort things out one at a time. I really want to figure out why the loud fan sound persists.
Old 10-12-2012, 10:03 PM   #32
jhaurimn
My Ride: 01' 330ci
The aux fan is probably what you are hearing and you shouldn't hear it very often .
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 10-12-2012, 10:07 PM   #33
always-there
Old 10-12-2012, 10:10 PM   #34
always-there
Old 10-12-2012, 10:12 PM   #35
always-there
I just found my problem..doh. I uploaded these two pictures so you fanatics can compare them. Do you see a difference ? Or better yet, the problem? I should know better than this : ) But I'll go ahead and have a laugh- so you should toooo ! Hahahahaha, oops.
Old 10-12-2012, 10:29 PM   #36
MercForHire
My Ride: M235i 6MT
your car is horrible! I have seen you post dozens of problems these couple month! life sucks!
Old 10-12-2012, 10:41 PM   #37
always-there
Oh Merc, you have no idea how much I had to fix. I'm almost done though : ) I know I said I would replace the dampers, but I haven't had the time. I looked under the car and reviewed what needs to be replaced. I need the driver side control arm and both struts. Should I give up?
Old 10-12-2012, 10:42 PM   #38
BimmersGarage
My Ride: E46 330i
Dear lord..
How did you manage to install the clutch on backwards
BimmersGarage is offline   Reply With Quote
Old 10-12-2012, 10:44 PM   #39
always-there
Old 10-12-2012, 10:46 PM   #40
always-there
I was so tired that day and nearly dehydrated-or better yet, dehydrated. That and I had to pick up my wife within the hour so I was rushing. Not making an excuse, but that's what happened. It was a rookie mistake, I should know better.
