Old 10-05-2012, 08:09 AM   #1
turbz
My Ride: '05 330ci Vert
NCS Expert Clown Nose DWA - Help!
Hey All,
I've been researching this for weeks and for some reason, i can't get my clown nose to flash on my car (2005 330ci vert)! I've set DWA to aktiv using NCS expert, but no luck! any other ideas?
I successfully coded my indicators to flash when locking/unlocking, but even though DWA is aktiv, my clown nose wont flash!
Thanks!
turbz is offline   Reply With Quote
Old 10-07-2012, 09:17 PM   #2
jeepo23
My Ride: 2008 X3, 6 Speed
Originally Posted by turbz View Post
Hey All,
Thanks!
You need to enable these three; last one is a flash when the trunk is closed after locking everything.
QUIT_OPT_ENTSCH
QUIT_OPT_SCHAERF
QUIT_OPT_SCHAERF_KLAPPE
They are all found in the GM5 module. If you are talking about the acoustic noise that you dont hear a beep its because 1) you didnt enable the akust options 2) you dont actually have the beeper/horn under hood.
And are you sure you are coding properly? After coding, read your file back and see if the changes actually took..
** Removed **
jeepo23 is offline   Reply With Quote
Old 10-07-2012, 09:45 PM   #3
turbz
hi jeepo23. all those options are aktiv! i have read the file back and the changes stick. I probably dont have the beeper/horn under the hood because i have enabled the akust options but dont get a sound. which is ok, i really just want the flash of the clown nose!
do you think i need to code the VO/FA?
Old 10-07-2012, 09:48 PM   #4
jeepo23
What do you mean by VO/FA?
If you enabled all those options I don't see why it wouldn't flash when you lock/unlock.
I just did this to a buddies car yesterday, enabling DWA and then the other 3 options did the flash.
** Removed **
Old 10-07-2012, 10:08 PM   #5
turbz
VO is the Vehicle Order in NCS which shows a list of options the car came with. There's a way to code the alarm to the VO so the vehicle thinks it has the alarm, but i don't think i need to go this far!
Maybe there's an error somewhere in my code and its not doing the flash? You wouldnt have a copy of your buddies GM5 module read out would you? This way I can compare!
Old 10-08-2012, 12:12 PM   #6
jeepo23
Never knew about the vehicle order stuff, but don't think you need to go that far to do this. And yes I do actually have his FSW file from the GM5.. This is what was last written to his car that gave him the flashing on unlock/locking.
File attached, change the extension back to .trc or .txt if it wont view in pdf.
Old 10-08-2012, 05:24 PM   #7
turbz
just checked and my file is the same! although, i think we may be talking about 2 different things. I already have my car indicator signals flashing during locking/unlocking. what i was looking for was the red light under the mirror to flash. lots of people say they got theirs to flash by making "DWA" akitv.
this is the light im talking about
http://www.*************/forum/attach...w-20mirror.jpg
Old 10-08-2012, 06:42 PM   #8
jeepo23
Oh the clown nose! Okay, Yah I thought you meant the sidemarker/corner lights flash.
Okay, I just verified with my buddy and his is flashing now so if your GM5 file looks like that.. I am going to assume you have some sort of wiring fault?
My 02 330 does it also after I enabled DWA..
Old 10-08-2012, 06:50 PM   #9
turbz
I just realised, you have MIT_OPT_ALARM set as nicht_aktiv. (mine is currently set to aktiv). Maybe i will try making my settings exactly the same as what you uploaded and see what happens!
next step i guess is to remove the mirror and maybe replace the LED for the clown nose?
thanks so much for all your help!
Old 10-08-2012, 06:58 PM   #10
jeepo23
No sweat, wish I could help more. Might want to check out the bimmerforums.com Coding Section and see if someone can give you more hints over there.
Old 10-09-2012, 12:20 AM   #11
jaysuper
My Ride: Bmw 325i
what tool do you guys use to program this?
jaysuper is offline   Reply With Quote
Old 10-09-2012, 12:48 AM   #12
turbz
I use NCS expert connected through the OBD port on the car
Old 10-09-2012, 05:47 AM   #13
jeepo23
NCS Expert.
Old 10-09-2012, 05:18 PM   #14
turbz
jeepo23, i tired copying all the GM5 settings in the FSW_PSW you attached and it didnt work! back to the books! haha thanks anyway
Old 10-09-2012, 06:04 PM   #15
jeepo23
Starting to believe that you have some other sort of wiring issue or busted LED with your mirror.
I would stop the coding and actually inspect the little clown nose.. lol.
Did you ask over on bimmerforums.com the Coding Section?
Old 10-09-2012, 06:11 PM   #16
turbz
Yeah i think that's the way to go. I'll ask the question at bimmerforums first. If I have no luck, I'll inspect the LED.
Old 10-09-2012, 06:14 PM   #17
jeepo23
Yah good luck man, wish I could of been of more help.
Unless it has something to do with your car being Australian and ours is North American? Maybe the vehicle order does play a role in this..
Old 10-09-2012, 06:21 PM   #18
turbz
I was thinking the same thing! When i set my sidemarker_US to akitv, my rear left LEDs (just the outer ring) are always on! but the LED on the rear right side are not! must have something to do with Aus/US vehicle order info. I'll keep you posted! thanks again
Old 10-09-2012, 10:01 PM   #19
NumbaOneNewb
My Ride: 2003 330CI Silver
I had this issue the other day. Did you mess around and unplug then plug back in the 3 wiring harness behind the fuse box recently? If not, if you have a digital multi meter, test that led.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 10-09-2012, 10:02 PM   #20
NumbaOneNewb
Are you using revtors profile as well?
