E46 Xi Forum
Old 10-05-2012, 01:32 PM   #1
john311tran
My Ride: awd + 5 doors
now what?
http://www.ecstuning.com/BMW-E46-325...ocks/ES252804/
i ordered those (through modbargains) and my shop is installing them (i'm sick as a dog). i just got a call and they said they can't install the fronts because there is no plate for the spring to sit on.
did i order the wrong ones? modbargains ordered them for me knowing what kind of car i had (325xiT) since the koni's i ordered were backordered.
thoughts/comments/suggestions?
john
john311tran is offline   Reply With Quote
Old 10-05-2012, 02:04 PM   #2
john311tran
i was told that i can just use the OEM spring plates but they are welded on..
thoughts?
Old 10-05-2012, 02:24 PM   #3
fernando629
My Ride: 325Xi 2001
I have a 2001 325xi, same set of struts and shocks and I used the OEM springs
fernando629 is offline   Reply With Quote
Old 10-05-2012, 02:26 PM   #4
john311tran
fernando,
how did you get the springs to sit on there? i'm using eibuach pro spring kit. the shocks (as you can see in the pic) has no plate to hold the spring. my oem ones are welded on there.
john
Old 10-05-2012, 02:28 PM   #5
fernando629
My Ride: 325Xi 2001
I used everything that was on there. Only replaced the struts and shocks.
Old 10-05-2012, 02:30 PM   #6
john311tran
i'm not sure you understand what i'm saying. IF i'm replacing shocks and springs. how do i get the springs to work with the bilstein fronts if they don't have the plate to hold the spring if the OEM plates are welded on. are there aftermarket ones i can purchase?
john
Old 10-05-2012, 02:34 PM   #7
e46alfonso
My Ride: AW 330xi manuel
Who is installing the struts, hispanics? They dont know what they're doing. The spring perch isn't welded to the strut, it can't be.
Remove the car from that shop and do the work yourself. All you need is a spring compressor (rent it), basic tools, and maby a friend.
You'd have to hammer the spring perches out with a rubber mallet, pb blaster or wd40 would help.
Old 10-05-2012, 02:43 PM   #8
john311tran
actually, the guy is hispanic. but that's besides the point. the shop has done me well in the past when i don't have time to work on the car myself (case in point).
i'll probably take a walk over in a little bit.
thanks for answering alfonso.
john
Old 10-05-2012, 02:43 PM   #9
john311tran
fyi, the fronts are NOT OEM. they are aftermarket (installed right before i purchased the car) would aftermarket perches be welded on by any chance?
john
Old 10-05-2012, 02:45 PM   #10
john311tran
update:
they just came on with a rubber mallet. phew. ugh, this is why it's so much easier to work on your own car.
john
