Old 09-22-2012, 04:31 PM   #1
Bobobo-bo Bo-bobo
My Ride: 2000 bmw 323i
Rattling noise from engine
I have a rattling noise coming from my engine bay. Im hoping there isn't something wrong
with my engine and its something minor. Anyone know what the noise is from? Thanks.
Bobobo-bo Bo-bobo is offline   Reply With Quote
Old 09-23-2012, 05:51 AM   #2
tkrotchko
My Ride: 2002 330i
The DISA valve can make a clattering noise (when mine went bad, it sounded like a valve problem).
The procedure to check takes 5 minutes and requires no tools:
http://forum.e46fanatics.com/showthread.php?t=748124
Originally Posted by Bobobo-bo Bo-bobo View Post
I have a rattling noise coming from my engine bay. Im hoping there isn't something wrong with my engine and its something minor. Anyone know what the noise is from? Thanks.
tkrotchko is offline   Reply With Quote
Old 09-23-2012, 07:17 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the DISA section in the first link below in my signature.
Old 09-25-2012, 02:32 PM   #4
Bobobo-bo Bo-bobo
my disa valve is running fine. The rattle comes more from the front. It doesnt get louder when I drive the car but it doesnt go away. Sounds more like something is wobbling around loose. its not a uniform rattle
Sent from my DROID BIONIC using Bimmer App
Old 09-25-2012, 03:03 PM   #5
lsteg
My Ride: 2001 330ci
video of the rattle?
lsteg is offline   Reply With Quote
Old 09-25-2012, 03:29 PM   #6
Bobobo-bo Bo-bobo
Video fixed
Old 09-28-2012, 09:15 PM   #7
Bobobo-bo Bo-bobo
Idky my video keeps turning into a picture but the rattle seems to be coming from the front of the engine like one of the tensioners or the pumps. More towards the left side.
Old 09-30-2012, 03:09 PM   #8
Bobobo-bo Bo-bobo
Looks like its coming from water pump cover.
Old 10-02-2012, 12:31 PM   #9
Bobobo-bo Bo-bobo
Water pump pulley is a little wobbly does this mean the water pump bearings are diekng and the pump needs to be replaced or can I replace just the bearing
Old 10-02-2012, 01:52 PM   #10
ryannel2003
My Ride: '04 Cadillac Deville
You'll have to replace the entire water pump. I picked up a Saleri (OEM) water pump from AutohausAz for $55 and the BMW coolant for another $20. Total with tax came out to right under $80. It's a good time to replace the thermostat as well, but I'm going to wait on that. $$$ is a little tight.
ryannel2003 is offline   Reply With Quote
Old 10-05-2012, 04:17 PM   #11
Bobobo-bo Bo-bobo
Ok ill replace the pump, hopefully thatll fix the noise
Old 10-05-2012, 09:05 PM   #12
shahbaz99
My Ride: Clean 330ci
I had a rattle from the front and it was also my water pump. Old one was plastic and the new one is metal so it a repair and upgrade as well. give it a try, doesn't hurt since you car is most likely due for a pump anyway.
shahbaz99 is offline   Reply With Quote
Old 10-06-2012, 03:32 PM   #13
Bobobo-bo Bo-bobo
I bought OEM with composite impeller. Not the best but OEM bearings supposedly last longer than aftermarket and since my bearings are the issue I thought id get the pump with strongest bearings.
