///M3 Forum
Old 10-05-2012, 04:34 PM   #1
NMAN85
My Ride: '02 M3 Convertible
Cover Dashboard Duct Hole :-( '02 M3
A while ago some guys installed aftermarket sound system and cut a hold into the duct to accommodate the Head system (Nav System). What can I use to effectively cover the hole? I'm installing a Dynavin system and don't want/need that to be open. Any suggestions?
FOLLOW US ON INSTAGRAM @The_Mom3ntum_Group
PERFORMANCE: ECIS Intake with RE Silicon boot, Euro Headers, Rasp Term, TopSpeed Muffler, AA Tune, RE Stage 1 Clutch, RE SS Clutch Lines, RE FCABs & RTABs, Bilstein PSS10s, Custom CSL Brakes Upgrade, Stop Tech SS Brake Lines
TBC.....
NMAN85 is offline   Reply With Quote
Old 10-05-2012, 04:59 PM   #2
Brevik
My Ride: Tiag M3
Man that is a bummer, but I think anything to seal it would be just fine. I would use some thin plastic and try to cut it close to size and glue.
Brevik is offline   Reply With Quote
Old 10-05-2012, 05:12 PM   #3
taylor192
My Ride: 2003.5 M3
Duct tape.
Old 10-05-2012, 06:02 PM   #4
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
you could use some dynamat
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
Old 10-05-2012, 06:58 PM   #5
NMAN85
I'm gonna look into the dynamat. Thanks fellas...if you have more suggestions keep it coming.
TBC.....
Old 10-05-2012, 07:26 PM   #6
$ilent ///M
My Ride: 03.5 M3 smg lsb
i used two piece of sheet metal. keep in mind this area gets hot
$ilent ///M is offline   Reply With Quote
Old 10-06-2012, 06:27 PM   #7
roadtrip1098
My Ride: 06 STi
There's an adhesive foil used for taping ducts together, it's pretty easy to work with. It's also made to handle higher temps. It's about the width of duc-tape but looks like aluminum foil.
roadtrip1098 is offline   Reply With Quote
