Old 10-05-2012, 05:12 PM   #1
hueyhy
My Ride: E46 330i
Small vibration under HARD acceleration
Can feel a little vibration under really hard acceleration (floor gas at 1st/2nd gear. vibration happens around 3k rpm or more)
otherwise the car is firm.
Recently replaced guibo.
But not sure if the vibration is because of that, or because of chopped and unbalanced tire.
(autocrossed last weekend and I believe the tires had a hard day)
Is it possible that sliding in autocross could cause the tire unbalanced and have noticeable vibration?
no vibration if going smoothly.
hueyhy is offline   Reply With Quote
Old 10-05-2012, 05:25 PM   #2
///MPR77
My Ride: 02 ///M3 Tri-Ped
What could be possible, is the GUIBO was installed incorrectly.
Did you check the CSB?
Old 10-05-2012, 05:29 PM   #3
hueyhy
My Ride: E46 330i
what could be wrong there?
Old 10-05-2012, 05:31 PM   #4
MercForHire
My Ride: M235i 6MT
vibration affected by engine RPM or speed?
Old 10-05-2012, 05:33 PM   #5
hueyhy
My Ride: E46 330i
neither
i can accelarte smoothly, won't vibrate at any speed/rpm
maybe torque?
Old 10-05-2012, 05:35 PM   #6
MercForHire
My Ride: M235i 6MT
engine vibration. mounts blown
Old 10-05-2012, 05:36 PM   #7
hueyhy
My Ride: E46 330i
I'll check that. Thanks!
Old 10-05-2012, 07:00 PM   #8
///MPR77
Take a pic of the installed GUIBO.
Old 10-05-2012, 08:47 PM   #9
BMW_CRAZY
My Ride: 2009 328i LCI BMW
Your having the same problem i had when i replaced the guibo in my car.. You have to make shure the shaft is in just the same way you took if out.. luckly i marked it and was able to put it back in its proper alignment ..
BMW_CRAZY is offline   Reply With Quote
Old 10-06-2012, 01:33 AM   #10
hueyhy
My Ride: E46 330i
thanks!
so you mean you had the vibration, because you didn't put it back the correct way?
and then you lift the car and changed it to the correct alignment, and the vibration is gone?
if i didn't mark it, is there any way I could fix it?...
Old 10-06-2012, 02:47 AM   #11
///MPR77
Originally Posted by hueyhy View Post
thanks!
Yes if it is mounted incorrectly, it will start vibrating within a couple thousand miles, at least in my case it did. It can be put on again correctly don't worry, you may have to drive it to a trustworthy shop, or better yet take it back to the shop that installed it, and explain the situation... Or did you DiY?
Old 10-06-2012, 03:43 AM   #12
hueyhy
My Ride: E46 330i
I did the job in a DIY garage with a lift. (actually I ddin't meant to replace the guibo, I was doing the short shifter job and then I found the guibo was broken, so I just ordered a new one and put it on)
can't remember if I marked it or not.
do I still need to remove the exhaust/heatshield to do the adjustment? that is painful...
it's just been a couple of hundred miles since I replaced the guibo.
Old 10-06-2012, 04:04 AM   #13
Alex323Ci
My Ride: M3 & 323Ci (sold)
that's not engine mounts. first thing i thought was that it was guibo. reading more of the thread I see others also think so. seeing how you don't recall installing it with attention to mounting flanges to arrows it a pretty good chance that's it.
Old 10-06-2012, 04:26 PM   #14
hueyhy
My Ride: E46 330i
just get under the car and checked the guibo.... found out it was installed in the wrong direction.
I didn't plan to replace it, so I didn't do enough homework on it. The old one broke when I was working on my short shifter so I ordered one and just put it on. was unable to search any info when I was at that garage...
have to do thing all over again. remove exhaust/heatshield, to get the guibo turned to the correct way.....
thanks for the information from all of you guys.
Old 10-07-2012, 03:18 PM   #15
///MPR77
No problem, Good Luck!
