Old 09-27-2013, 10:48 AM   #1
pyro225
My Ride: 328ci
Non oem cam intake sensor issue
Ok I had an issue with my car and as I wasn't one hundred percent sure the sensor would fix I got
A mid price one from euro car parts (40) rather than from BMW which was nearer 100. The new one seems to have fixed the problem however it comes up with a permanents can sensor fault when I plug in the peake reader.. But as said it runs fine any ideas? Also the after market can sensor didn't have the fat cylinder at the bottom and thin on top it was fat all the way
pyro225 is offline   Reply With Quote
Old 09-27-2013, 11:09 AM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
What's your question?
Old 09-27-2013, 11:17 AM   #3
trizzuth
My Ride: 234k, 16yr old B3AST
Before you bought then discounted cam sensor, you should have searched E46Fanatics for "OE cam sensor" or just "camshaft position sensor" or even "CPS" as you would have found your answer within minutes, which is of course to never use an aftermarket part for these particular sensors.
trizzuth is offline   Reply With Quote
Old 09-27-2013, 11:28 AM   #4
Mr Podman
My Ride: E46 Coupe
There are a lot of posts about aftermarket sensors not working.
Then again, the OE sensors are pretty crappy too, else why are we replacing them?
Bottom line: The error code on your Peake tester says it isn't working.
Replace it with an original equipment sensor (pulse generator).
I bought mine online at Tischer for $85 about 5 years ago. Pelican Parts might be a good source too.
Mr Podman is offline   Reply With Quote
Old 09-28-2013, 05:00 PM   #5
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
use OE CPS, please
I replaced the intake CPS on my 2002 e39 530i with this non-OE one from ECSTUNING...
http://www.ecstuning.com/BMW-E39-530...ake/ES2091353/
...and it went bad in two months. ECSTUNING was great and shipped me a replacement (no questions asked) after verifying my original purchase. I installed it and it has been fine now for about a year.
Another unrelated case: I bought a cheap coolant expansion tank from ebay for my 2004 e46 325Ci and the damn thing had no magnet on the internal float for the coolant level sensor. So my coolant light would always stay on. Then that tank blew out a month later causing the engine to overheat and blow the head gasket. i saved $50 on the cheap tank but cost myself $2k for a repacement engine.
From now on, I will always buy OE parts where possible.
