Sponsored by BimmerWorld
Old 10-17-2012, 07:15 PM   #1
prisonerofdoom83
My Ride: E46 E30 Tacoma
megan rear camber kit
i see a bunch on here have the coilovers but i did a search and couldnt find any feedback on here . anybody have these on there car ??
prisonerofdoom83 is offline   Reply With Quote
Old 10-17-2012, 07:19 PM   #2
TrippinBimmer
My Ride: Just Fast!
spc ftw
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 10-17-2012, 07:32 PM   #3
prisonerofdoom83
looks like they have 2 diff ones which ones do u have
Old 10-17-2012, 07:44 PM   #4
prisonerofdoom83
also i would like to know which front camber plates to use on the hks coilovers .
Old 10-17-2012, 08:18 PM   #5
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
I heard great things about the them, but with the Steel SPC's the inner rubber bushing can slide out of place in the hole, causing the arm to slide against the rear subframe (metal on metal). Apparently some guy in Bimmerforums sells limiters that install on both sides of the inner aspect of the arm to prevent the bushing from sliding out. FYI
I've been researching the crap out of these as well as offset rear camber bushings (like Whitelines) but so far the best I've come up with is if you want it right you got to pay to play. the VAC motorsports ones look real nice but $$. Just my 2 cents
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 10-17-2012, 09:57 PM   #6
prisonerofdoom83
theres so many brands there all around 300$ bucks . thanks for your help i will be doing more research before i buy . ill most likely buy before months end
Old 10-31-2012, 11:37 PM   #7
prisonerofdoom83
are the adjustable front camber plates interchangeable between coilovers or do u need a specific one for the brand coilovers you have . mine are hks hypermax btw
