Old 10-06-2012, 03:50 AM   #1
Davinci323iE46
My Ride: Bmw 323i e46 1998
Question Sedan one touch function not working!
Hey all my Bmw 323i's windows have been giving me grief lately. When i say that i am actually referring to my rear left window the one touch function works going down but wont work going back up i need to pull the switch all the way up just to get the window to start going up! i have brought new switches for both the front controls and on door controls replaced and still no luck! any ideas? maybe a way of resetting sedan windows?
Thanks.
Davinci323iE46 is offline   Reply With Quote
Old 10-06-2012, 04:49 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Pinch protection possibly not working right?
Could be the window needs to be re-initialized?
Could be the switch in the gaskets is bad?
Usually to re-initialize you roll the window all the way down, pull up on the switch to close the window and continue to hold the switch for about 5 seconds once the window has closed, usually you need to do this 2 times??
Info should be in the owners manual for the sedan and coupe as I recall.
Convertible is a very different procedure for anyone else reading along.
