Old 10-06-2012, 05:28 PM   #1
IrocThe325i
My Ride: is turning japanese
Thinking about building a custom intake mani.
soooo im probably gonna pick up a used intake manifold and make a custom aluminum sheet metal intake.
anybody have one laying around they wanna donate???
also do you know if I can code out the sensors for the disa and such computer controlled gadgetry on the intake manifold with an AA tune???
and i know. I'm probably gonna end up losing power from doing this but i have such a burning hatred for this silly ugly plastic manifold.
hopefully ill have it made and installed by spring if all works out. Main issue will be the computer side of it.
IrocThe325i is offline   Reply With Quote
Old 10-06-2012, 05:55 PM   #2
IrocThe325i
hard to believe i can't find an aftermarket intake manifold for m54s...
Old 10-07-2012, 11:20 AM   #3
Rimon08
My Ride: 2002 BMW 330i
bump. interested in this
Rimon08 is offline   Reply With Quote
Old 10-07-2012, 11:30 AM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I'm curious why you're doing this.
If it's mostly for looks, I'd just muse that there might be some advantages to the plastic one we have. Also, getting it waterproof seems like it'd throw some curves your way with fabrication.
Also, wouldn't aluminum transfer a lot of heat into it that the plastic probably insulates the intake from (a tad)?
Could I maybe interest you in something from our ICV or TB cleaning department instead?
Edited: I thought you meant air filter housing at first...now I'm even more curious why you'd want to do this.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-07-2012, 12:05 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
It's definitely possible to make an "equal length" manifold. But you're going to need to do a lot more work than just a new mani. The throttle body, and all intake equipment will need to be repositioned.
Something kinda like the m3 intake manifold.
Old 10-07-2012, 12:39 PM   #6
IrocThe325i
i assumed the ICV is built into the throttle body? If so there's no reason the throttle body which i believe is just a four bolt square mount can't be relocated to another location. The DISA can be removed as long as the computer will accommodate such a mod. The PCV can be changed because thats as simple as a vacuum vent for the crankcase.
Fuel rail and injectors can also be replaced with aftermarket ones if i choose to do so.
Im going to attempt to keep the runner lengths near stock length and have a plenum that is nearly the size of the motor.
honestly as r*cey as this sounds its going to be more for just something unique and cool rather than performance... like a cold air intake, since we all know those hardly increase performance.
Damn BMW makes everything so efficient.
Old 10-07-2012, 12:56 PM   #7
Iceman00
Banned User
My Ride: E90 6MT
So is it purely for look or performance? Because if it's performance, what are you using for your airflow model?
The honest truth is there isn't anything to be gained changing the intake manifold because the head flows so poorly as it is. Spend time on that, and leave the manifold alone.
Old 10-07-2012, 02:03 PM   #8
IrocThe325i
i was hoping ud pop in!
its more for looks. i hate the plastic one.
im looking to pick up a head to have built but its gonna be a 3-4,000 dollar project and im not sure its worth it on a 2.5.
i rather put it towards an s54 swap
Not from my iphone
Old 10-07-2012, 02:26 PM   #9
dmax
dmax's Avatar
I'm sorry, OP, but now that I understand it's the intake mani you want to build, I'm thinking it'd be headache after headache...and then more headaches when you get to the computer stuff. There are so many ports...things that need to be bolted on, to say nothing of the accuracy you'd need to get the intake tubes to fit exactly where they need to fit and fit tight.
Maybe you could just make a nice aluminum cover for it and be satisfied.
Please don't take this post as a challenge to push you to do it either. It sounds crazy, even assuming you have all the skills and tools to do this...which I assume you do.
Mangofy your E46!
Old 10-07-2012, 02:59 PM   #10
IrocThe325i
my friend works at a race car fabrication shop. He can have a flange cnc'd to fit the head. Then its just a matter of making six runners to match the port on the flange and gradually shape into a circle which will have a velocity stack attached inside of the plenum. Plenums the easiest part. Where the runners go in it will be a flat piece of aluminum and then the rest will be shaped either round or oval idk thats for my fabricating friend to decide. Then the flange for the throttle body also to be machined.
the hardest part will be where the fuel injectors seat in, i have no idea what the seat looks like.
that and figuring out what to do with the excess vacuum lines and such.
Old 10-07-2012, 03:35 PM   #11
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Not from my iphone
I had my head redone on my old 2.5 ported and polished with new custom valve guides, cause they didn't make Standard size valve guides, he flow benched it before and after and it picked up 85% more flow over stock. And it only cost $1400. I also added cams and springs. Total was 3200 installed. I could have done it my self and it would have only cost about 2100
325CiMaN is offline   Reply With Quote
Old 10-07-2012, 04:05 PM   #12
peytonracer4
:D
My Ride: '00 328i
Power gain?
Old 10-07-2012, 04:16 PM   #13
325CiMaN
284.2rwhp, and 297.7rwtq, I'm trying to find my dyno paper now.
Old 10-07-2012, 04:21 PM   #14
325CiMaN
I'm also trying to do the same thing but in stead of aluminum I'm going to make it out of aluminum pieces and make molds and make a final one out of carbon fiber, that should make more power and hold in less heat. But I'm trying to do this on a 3.0l cause i swapped my 2.5 for it.
Old 10-07-2012, 05:59 PM   #15
peytonracer4
:D
My Ride: '00 328i
Um... You had 284rwhp after a port and polish? Are you kidding?
Old 10-07-2012, 06:02 PM   #16
325CiMaN
Cams too, high compression pistons 11.5:1 that's why i am looking for my dyno results paper.
Old 10-07-2012, 06:03 PM   #17
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
He also had cams installed. I assume high lift/duration cams and custom tuning done. Still have no idea how he made S54 power for $3000 without boost.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 10-07-2012, 06:07 PM   #18
325CiMaN
Yes 272 shrick cams and it took a lot of crunching numbers with my Machinist...i mean allot.... Almost 2 months.
Old 10-07-2012, 06:10 PM   #19
325CiMaN
But that motor is toast now, but anyway i would like to see how he makes this intake mani, i am trying to incorporate the disa tho.
Old 10-07-2012, 08:43 PM   #20
peytonracer4
:D
My Ride: '00 328i
He added like 80% power without boost.
There's no way.
