Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Southwest
Southwest
AZ NM NV OK TX UT
Old 10-06-2012, 07:11 PM   #1
rookie2k
My Ride: 2000 328I
Angry Oil housing nightmare...stripped threads :(
As the title states i've stripped the threads on the top piece of my engine oil housing. Long story short i was stupid (i blame it on a faulty torque wrench) and now had to re-thread one of the holes...problem is i'm now leaking more than ever.
Anyone want to offer some advice?
I've got a couple options but just wanted some advice/help from the local guys.
Should i refill the hole and re-thread to the proper size? If so anyone know where i can find an affordable shop that does aluminum welding?
Or should i just stick with it and try and seal the leak?
Thanks in advance
rookie2k is offline   Reply With Quote
Old 10-06-2012, 08:11 PM   #2
04330ciZHP
My Ride: E46 E90
Are you talking about the threads in the block for the oil filter housing?
04330ciZHP is offline   Reply With Quote
Old 10-07-2012, 12:26 AM   #3
darksideracer69
My Ride: 01 325ci
that sucks dude, try heli coil or a time-sert insert.
IMAG02051
Old 10-17-2012, 12:27 AM   #4
rookie2k
My Ride: 2000 328I
Yeah i mean those threads on the block...FML. Well i ended up making some new threads and getting a bigger bolt. Needless to say i'm still leaking...even more than before. Time to sell the bmw i think. Plus the passenger window is starting to give me hell and vanos seals are definitely done. Yes i know, easy fix for the most part...but just something else to be mad at :/
Anyone work on cars during the weekends, like just get together and work on cars not a shop. We should start a workshop day...what do you guys think?
Old 10-17-2012, 12:29 AM   #5
rookie2k
My Ride: 2000 328I
Ohh shout out to Darkside, almost met up when you were in Dallas but i ended up getting busy. My bad
Old 10-17-2012, 06:13 PM   #6
darksideracer69
My Ride: 01 325ci
lol its ok man, i was more than busy anyways
IMAG02051
engine oil housing, gasket, leaks
