Old 07-27-2015, 12:16 AM   #1
Lamtran503
My Ride: 2003 325xi
Adding subs for the first time.
2003 e46 325xi stock sound no Harmon and Kardon
As I am reading and watching videos on how to add subwoofers, I'm wondering why do people connect wires to the stock amp and rear speakers on a e46? I got 2 tens by JL I need to get an amp and to install but I'm not sure if I should install it through the rear speakers and BMW amp but I don't know the purpose of it. Any knowledge and recommendations on amps would be great! Thank you in advance !
Lamtran503 is offline   Reply With Quote
Old 07-27-2015, 05:20 PM   #2
kd7iwp
My Ride: 2001 325i
I believe people are tapping into the wires from the stock amp to get line level signals for the subs/amps. The speakers in the car are all likely wired directly to that amp so it's an easy spot to tap into. If you have an aftermarket head unit with line out plugs you would have to put new wires under the carpet going to the rear for your subs. In fact, if you replaced the stock head unit I wouldn't be surprised if you'd have to rewire the speakers as it probably won't work with the OEM amp.
kd7iwp is offline   Reply With Quote
Old 07-27-2015, 08:22 PM   #3
MileHighBMW
My Ride: 325 xi wagon
I just tapped into the harness Pre-amp.
Used an LOC and easy connects like everyone says not to... worked amazing unless youre going for audiophile perfection this is the way i will reccommend.
Made the entire install a 40 min job.... best of luck if you have any questions holler.
MileHighBMW is offline   Reply With Quote
Old 07-30-2015, 12:02 AM   #4
Lamtran503
My Ride: 2003 325xi
Im very new to how stuff works so bare with me. You got a line out converter and connected it through the pre-amp in your car and not your rear speakers?
Another question is what wires did you tap in to use the LOC? Any splicing on the wires or stuff like that?
Old 07-30-2015, 01:05 AM   #5
MileHighBMW
First of all pardon my excellent artwork. I'm in a hurry
This is your amp's location, if you have a wagon its cake to get to, I guess guys with trunks have a harder time, but either way you have to get to it anyway.
You can use the LOC from the rear speakers but that would be post amp signals, I wanted to use PRE amp signals so I tapped in right where my "harness" arrow is... You can remove the tape that holds all that together and just tap in right there.... I chose to do it this way because the remote wire is right there too so they are all in 1 location....
Once you get there the LOC has to be hooked up to the following:
rear R-
rear R+
rear L-
rear L+
and then SOME require a ground too... which is also available right there at the harness.
The harness once removed can be split into two sections, it will be blatantly obvious how to do this once you disconnect the harness.. There is a gray connector and a black connector. Knowing this information the folllowing table should help out with the rest, again if you need anything just holler.
Right + Blue/black grey8
Right - Brown/Orange grey16
Left - Brown/Orange black29
Left + Yellow/black black37
Remote - solid white, grey10
Old 07-30-2015, 10:15 PM   #6
Lamtran503
My Ride: 2003 325xi
rear R-
rear R+
rear L-
rear L+
I don't have colors you have which is weird.
Here's a pic Click image for larger version
Old 07-30-2015, 10:16 PM   #7
Lamtran503
My Ride: 2003 325xi
Old 07-30-2015, 10:25 PM   #8
Lamtran503
My Ride: 2003 325xi
I lied I found them god this thing is hard to get to
Old 08-03-2015, 01:02 AM   #9
MileHighBMW
How did the install go, you get it?
Old 10-26-2015, 11:14 PM   #10
Lamtran503
My Ride: 2003 325xi
Super late reply been very busy but yessir thank you so much!
Old 10-26-2015, 11:30 PM   #11
Mflara20
My Ride: 04 330i
I want to do this as well. Can you snap some pics of your work?
Sent from my SM-G925P using Tapatalk
Mflara20 is offline   Reply With Quote
