Sponsored by BimmerWorld
Old 10-07-2012, 02:49 PM   #1
Russian172
My Ride: e46 sedan e46 m3
How do I find which bearing is bad
Is there a trouble shooting way or a specific method to finding out which wheel bearing is bad ?
Russian172 is offline   Reply With Quote
Old 10-07-2012, 02:56 PM   #2
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Yes there is, when you turn left it loads up the right side when you turn right it loads up the left side, so take a left and right turn, if its louder when turning left it's on the right and if it's louder when turning right is on the left. Then when you figure or what side it's on jack that side up and shake the wheel. One hand on top of wheel one on bottom and try to move it back and forth. So push on top of wheel and pull on bottom, and do that repetitively. If there's movement it's bad. there shouldn't be any moment.
325CiMaN is offline   Reply With Quote
Old 10-07-2012, 04:18 PM   #3
325CiMaN
You able to fine the culprit?
Old 10-07-2012, 05:43 PM   #4
Russian172
Not yet man I just got to work but I will as soon as I can
Thanks for the advice braahh
Old 10-07-2012, 05:45 PM   #5
325CiMaN
Yep your welcome man, good luck with trying to find it
Old 10-08-2012, 12:28 AM   #6
Russian172
I found a nicely priced kit (40$ for both) but not sure about the fitment as is says it will fit m3 z3 318 not sure if it ll fit mine 2002 325
Old 10-08-2012, 12:31 AM   #7
Russian172
Here is the description
Old 10-08-2012, 03:12 PM   #8
Russian172
Anyone ?
Old 10-08-2012, 08:34 PM   #9
Russian172
Really don't wanna make another thread to see if the bearing in the pic is compatible
