Old 03-15-2013, 07:41 PM   #1
Goldsworthy
My Ride: Black 2001 325ci
Installation : Corner light lenses
Hello!
I have purchased the Depo LED corner turning light lenses in smoked out with white LED's. I just tried to install them and had no issues until I tried snapping them in. In doing so it won't click in properly and it won't go into position.
The OEM lenses fit perfectly fine, and this doesn't make any sense to me.
Any suggestions would be much appreciated, I don't want to be screwed over.
Goldsworthy is offline   Reply With Quote
Old 03-15-2013, 07:46 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Well they are aftermarket so fitment issues are expected. I'm not sure how it is for your car but did you get the right type? As in the one with the screw in part or the snap in
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 03-15-2013, 08:43 PM   #3
Goldsworthy
The previous one was snap in and so is this one as well. It goes in but is positioned over to the center to much and doesn't quite click in all the way. :S
Old 03-15-2013, 09:44 PM   #4
Slyde
My Ride: 2001 M3 TiAg
I had a set of Depo replacement corner lenses and had trouble fitting them. I had to slap them into the socket to get it to fit... but only the passenger side did fit with that slap. The driver side lens cracked when getting slapped and never did click into position. Your experience makes me think another set of Depo will render the same fitment issue.
Slyde is offline   Reply With Quote
Old 03-15-2013, 11:28 PM   #5
Goldsworthy
Such a piss off, thanks for the input man. Can't express how frustrated I am, it's supposed to be an easy install.
corner, diy, install, lenses
