Old 10-07-2012, 08:53 PM   #1
trive2
My Ride: 1989 BMW 535i
E46 Air-Con problems
So, to get me back for hitting a Kangaroo the other day, my 330i's Air-Con has completely decided to fail in 105 degree days.
Hurrah.
It's always been crap, only noticeably cold on cold days and never really that chilled on really hot days.
Anyway, on Saturday, I turned it on after work and suddenly it was hot/room temperature. I've double checked it and it's definitely room temperature air. Absolutely no refrigeration at all. It also makes a funny whining/sucking noise now coming from near the climate control panel, constant whilst the system is on and only goes away when I completely turn it off (aka, blower fan off).
What could be up? I'm driving around my $600 Volvo because my piece of **** $20,000 BMW is cooking me all day.
trive2 is offline   Reply With Quote
Old 10-07-2012, 09:21 PM   #2
Lusticles
My Ride: 325Ci
Is hitting a Kangaroo in Brisbane as common as hitting in a deer in rural United States?
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 10-07-2012, 09:36 PM   #3
Cyanide72
My Ride: 2002 325i
Recharge the system with new freon. Make sure you vacuum out all the existing freon (or at least whatever is left of it) before filling it back up. There should be a sticker on your hood that'll tell you how much to refill.
Cyanide72 is offline   Reply With Quote
Old 10-08-2012, 12:09 AM   #4
trive2
If it instantly and suddenly discharged itself completely of gas, then I suspect that refilling wont help.
I recently had the disk sensor under the bumper tear off? It's the one that sends the signal to the heated washer nozzles? Found out today, could that be it?
Old 10-08-2012, 12:16 AM   #5
choxor
My Ride: JDM
Take it to a shop and have them check for a leak, which I assume you most likely have.
Old 10-08-2012, 12:17 AM   #6
illestminimike
My Ride: Project Drama
Does your temp sensor work on your cluster?
Old 10-08-2012, 01:03 AM   #7
PH03NIX46
My Ride: 2003 M3
If your exterior temperature sensor (located underneath the front bumper) is broken, then get it replaced.
Since your fan works...check to see if the A/C needs refilling?
Otherwise, I'd suspect you've got a leak. Best to bring it to someone who can find it faster than you.
Eibach | Sportline | OEM Euro Headers | TTFS
PH03NIX46 is offline   Reply With Quote
Old 10-08-2012, 06:42 PM   #8
trive2
Yeah, that temperature sensor got torn off a month ago hahaha I replaced that. Now the other one's ripped off. *DOH*
Old 06-27-2013, 05:46 AM   #9
trive2
*update*
Turns out it was the rather common corroded Evaporator leak.
