Motorsports & Track Forum by BimmerWorld
From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast Sponsored by BimmerWorld |
#41 |
Is the tape for any rocks flying up or what? Sorry noob here.
![]() CarbonBlackCinnamon 30% Tint/Black Grilles And Gills/CF Wrapped Trim/MeganRacingExhaust/DepoSmokedCorners |
#42 |
Stay stock my friends!
I'm confused then. I have eliminated my understeer by keeping my front tires at the maximum door jamb pressure (32) and the rears in the towards the low/middle side of pressure.
I don't have understeer...mine it pretty neutral right now. When I apply gas lightly through turns, I push out the rear end and definitely notice throttle steering. You might increase the throttle steering response with higher pressure, but a little more pressure does make the tire diameter greater, and thus the same angle of steering causes more turning. This is what I've read in many places and have direct experience with...just saying. Mango, I agree, though, that I bet a lot of time has to do with contact patch and that using door jamb, even at autoX might be better than 40 all around (though that might be closer to your recommended pressures than mine). I'm 29-32 in front and 33-41 in rear (I think).
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#43 | |
Because of this, there is no blanket statement that will *always* be true, as the balance between the front and rear are relative to one another. But in a situation like Mango described, where he's running 40PSI, running slightly higher in the rear will move the car's tendency more towards oversteer. If his pressures were lower (say 30 PSI), the same might not be true. Every tire is different. But from my experience, when you're at the high end of your optimal range of pressures like that, running higher in the rear will loosen the back end up. I do this in my E36 on tighter courses where I want to steer more with my right foot. I run star specs, which have a very stiff sidewall and squared shoulder. Other tires would take more pressure to slide off in grip on the top end. But regardless, 40 cold is on the high side.
-Nick
#44 | |
also the pressures on the door jambs are NOT recommended for autocross. when you're cornering under extreme conditions your tire gets much more force than under street driving. you cannot drive as hard on the street as you do in autocross. i don't care who you are and where you drive you just can't do it. in his original pictures you can see the tire tread patch. then you can see slight wear on the outsides of that. that is a sign the tire did not have enough pressure to deal with the force it had on it and needs to be increased. the tire will flatten the more weight you put on it and the sides will start to "roll over" he should be running at least 40 psi. at my autocross yesterday i ran about 41 all around and still had slight rubbing outside of the tread patch. anywhere outside of that tread patch is considered to have zero grip.
#45 | |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
Sometimes I've seen tape on the headlights, never known the reason for that. I always just assume because racecar.
E46Fanatic's resident mathemagician
![]() Last edited by Zell; 10-08-2012 at 10:00 PM. |
#46 | |
during autocross there is no point. also taping your car during autocross is kinda dumb unless you have r compound tires that literally pick up little rocks and throw them at your car.
#47 |
I'm In for the post upgraded sway bars"body roll" pics.
#48 |
I really like that you put your car to the test, mango. It gives me faith to push my further to it's limits, and I kinda' did that today. I know I have repairs to do, but you know us and our constant need for an adrenaline rush. Today, I decided to push the car a bit harder. They're were a couple of bends and curves, and I pulled out of em' with the rear sliding just a tad bit. It felt good! Only because I've never experienced the amazing control the 330 offers when it's pushed hard. Then I saw your post and smiled, haha. I'll be buying front/rear strut bars and front/rear h&r sway bars to improve the handling. I love the way the power train puts it's power down, but I don't think BMW's are street brawlers-in the drag racer sense. I think these cars shine in the track/autocross.
#49 |
Platinum Plus Quality
good advice, nick, although i know the basics of understeer, oversteer, lift throttle oversteer, weight transfer, etc. i do plan on knocking my pins next time before my next alignment. and yes im positive its my wheel bearings.
i did let my car idle after runs for about a minute. still great tips. and dmax, afaik, raising front tire pressure relative to the rear will introduce even more understeer. it wasnt that bad. Sent from my SGH-T989 using Bimmer App
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#50 | |
in my front left i had a humming for a few days. now it sounds like, what can only be described as, a dry bearing noise that is only present when moving. i also have a ever so faint clunk/click at random bumps.
#51 | |
Too bad the Z3 member matched their level of performance. That was a major lost opportunity on BMW's part. It is strange how two cars that look so similar on paper could end up so different. Sorry, but I still have a soft spot for Miatas! If they had made a NA version with a small V6 and about 100 more HP, I probably would never have bought a BMW. |
#52 | |
#53 | |
![]() Now, if you have tons of HP, then it can be fun and/or scary. Some people have the impression that it just involves flooring it, which is pretty much true with cars with normal amounts of HP. But, if you ever get to drive a car with obscene amounts of HP, then it becomes something completely different. Tiny corrections can upset the car, and put you in to a cycle of back and forth corrections. But Autocross is way more fun, and more within the reach of the average guy, and you are not risking a $10-20k engine when you do it. |
#54 | |
Sorry to hear about the wheel bearings. I hope it's the fronts, for your sake, if you DIY them. Getting some more camber up front will make a noticeable difference. Depending on how much you squeeze out of it from knocking the pins out, you may want to dial the toe back a little to save the tires some wear.
-Nick
#55 | |
Right, i'm currently toe in -.10 all the way around (since I do highway driving) but i might set dial it down or zero it out next time. I believe knocking the pins out is good for half a degree of camber (according to tis)I'm ordering all four corners for the wheel bearings. Including all new hardware; axle nuts, dust caps inner and outer, snap rings
#56 | |
#57 | ||
Good luck with the bearings. ![]() Quote:
I keep up with most of the NA Miata's. Some of the FI ones are real fast though. There are a few at my local club that are pushing out some nice power. They're lighter, smaller, more maneuverable, and faster than a 3-series. There's just no way to match their times. Though, the satisfaction of having a refined, pleasurable daily driver like a 330i, that's also very capable out there without any modifications whatsoever...that's worth its weight in gold, IMO. It's all about enjoying the car and learning. There will always be someone faster. Having fun and improving as a driver is
-Nick
#58 |
Fully Deeked Out
I demand gopro footage of future mango autocross action (MAA).
#59 | |
I agree man. I wanted one bad that day. I would do 5D Mark II footage but need a sturdy mount first
#60 | |
