Unlocking the doors - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-07-2012, 09:27 PM   #1
YOLO89
My Ride: Hooptie
Unlocking the doors
Sometimes my key fob will unlock all the doors when I push the button twice but at times it'll just open driver side. When it does the doors when they unlock sound almost like they are struggling to do so. Is this the key fob issue or something with the door locks?
YOLO89 is offline   Reply With Quote
Old 10-07-2012, 09:30 PM   #2
Lusticles
My Ride: 325Ci
Sometimes mine will only unlock the drivers door even after pressing twice. I will have to relock the car, then unlock it 'twice' again for both doors to open.
Never really thought anything of it. Now that I think about I would also like to know why this happens.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 10-07-2012, 09:34 PM   #3
YOLO89
My Ride: Hooptie
Yeah that's how mine was/is. It gets pretty annoying after awhile haha. Hopefully someone has had this issue and got it resolved.
Old 10-07-2012, 09:43 PM   #4
kaldE46
My Ride: 2001 325i
Same
kaldE46 is offline   Reply With Quote
Old 10-07-2012, 10:05 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
Sounds likely a GM5 module issue, however, weak keybob and/or a weak battery in the car could also contribute to this as well.
Suggest you check the link below in my signature regarding door locks.
Also you did not mention what year your car is and whether or not you have auto door locking enabled on the car.
If your car is a 2003 or older then I would start to question the GM5 module.
Old 10-07-2012, 10:32 PM   #6
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
It happens to 2004 cars as well. It would be rare for the fob to cause the OP and lusticles problem. Most likely the general module (aka GM5 module) is to blame
scottjoh is offline   Reply With Quote
Old 10-07-2012, 10:43 PM   #7
YOLO89
My Ride: Hooptie
My car is a 2003 and I don't have auto door locking enabled. Did know that it was possible.
Old 10-08-2012, 03:10 AM   #8
jfoj
Scott, you may have more info because of the repairs you do and the amount of questions you answer, however, my reference was based upon me only really seeing the older cars having issue, usually between year 9-10. I am sure younger cars may have issues as well, but I have only run across about 6-7 cars with issues so far myself.
I also see that if auto door locks enabled the door locks get far more operation cycles over the same period of time as a car that does not have the auto door locking enabled.
