Old 10-07-2012, 10:41 PM   #1
asma123
My Ride: E70x5 m3conv m3coupe
shifter platic piece broken on zhp
Hi, just today I was driving when all of the sudden I'm shifting and the stick came out and would not go into gear. As I kept driving I realized that it will go into gear as long as I pressed down on the stick when shifting.
I took the top part appart and I noticed that part
25111220600 which seems to hold the ball in place had a few broken clips.
Great.. Now I have to replace it.
I'm wondering if it's possible to remove this plastic piece from the top or would it be required to jack up the car and then remove the bolts that hold the shifter and remove that way. Any input would be great. thanks.
asma123 is offline   Reply With Quote
Old 10-07-2012, 10:50 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
http://forum.e46fanatics.com/showthread.php?t=856105
Should answer your question. Good luck!
