Old 09-19-2012, 09:15 AM   #1
318ise
My Ride: 318i se
engine rattle help
hi guys, recently joined the forum but I have been on from time to time !
I have a problem with my 1999 318i , over the past few days a rattle has appeared .... it seems to be coming from inside the inlet manifold somewhere but its hard to narrow down where it is coming from . The noise does go away when the motor is under load and with throttle pressed but it does sound nasty at idle and de-acceleration.
VIDEO;
Is the anything mechanical that could be making this noise to the rear of the throttle cables ?or beneath that area ?
has anyone had similar problems ?
the car has covered 120.000miles but with full service history .
any help would be greatly appreciated,
M
318ise is offline   Reply With Quote
Old 09-19-2012, 10:16 AM   #2
GSherbs
My Ride: 2002 330 xi
Sounds like the DISA... replace it
Item #8: http://realoem.com/bmw/showparts.do?...13&hg=11&fg=40
GSherbs is offline   Reply With Quote
Old 09-20-2012, 07:23 AM   #3
318ise
My Ride: 318i se
what is the adjuster unit is it a common fault ? has it got moving parts ? thanks
Old 09-20-2012, 07:43 AM   #4
GSherbs
Yep. Sure does and it is a common failure.
Search youtube for DISA replacement - quite a few videos showing how it fails and makes noise.
Old 09-20-2012, 08:27 AM   #5
318ise
My Ride: 318i se
thanks for the assistance! I'll let you know how it goes ,
M
Old 09-20-2012, 08:33 AM   #6
GSherbs
Not a problem - definitely report back success or failure. Too many threads end without conclusions.
-G
Old 09-20-2012, 04:10 PM   #7
318ise
My Ride: 318i se
Sure will! I might even make a video of the repair/removal if it will help people diy. I cant find a video on youtube that caters for the M43 4cyl but im sure i'll figure it out ! Thanks again.
Old 10-07-2012, 01:34 PM   #8
318ise
My Ride: 318i se
Hi there ,
the conclusion is that it was the DISA valve which had play in the butterfly mechanisim , replaced it with a new unit and there is no noise ... AWSOME
thanks GSherbs for you pointing me in the right direction.
Old 10-08-2012, 08:02 AM   #9
GSherbs
Welcome!
Glad the issue is fixed!
