Old 10-08-2012, 08:01 PM   #1
mikes325xi
My Ride: 04 bmw 325xi
Stripped oil filter cap removal
OK i have seen a few threads on this but none with a soulution for me. I was changing my oil last week and i stripped the 36mm plastic bolt on the oil filter cover. It was already starting to strip and the last person who changed didnt even reset the computer so i'm guessing they over torqued it and/or put the gasket on wrong. Now before everyone starts yes i was turning it the right way, yes i was using a 6 point 36mm socket and even tried a pipe as leverege. Now the bolt is too stripped to remove with any 36mm socket, breaker bar etc My question is how to remove this? socket for outer diameter? I'm buying a new cap so ruining the old one doesnt matter i just dont want to get all sorts of little scraps of plastic in my oil. thanks in advance e46fanatics
mikes325xi is offline   Reply With Quote
Old 10-08-2012, 11:02 PM   #2
John in VA
My Ride: 328i/325xi
Are you able to get leverage on it with a big pair of Channel Locks, or maybe Vice Grips and a deadblow hammer?
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 10-09-2012, 12:04 PM   #3
moiz21
My Ride: 1999 323i 5-SPD
I read on the forums a while back that someone had this exact same problem. So he drilled a hole in the cap and stuck a thick screw driver in there and used a pipe for leverage to unscrew it.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 10-09-2012, 12:12 PM   #4
jhaurimn
My Ride: 01' 330ci
Vice grips, get a little angry, cuss a little bit, and you should get it loose. Buy a new filter cap afterwards too obviously.
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 10-09-2012, 12:18 PM   #5
WDE46
My Ride: '13 128i, '04 330Ci
Go to homedepot or sears or lowes and buy a strap wrench. It is a simple device made from something similar to an engine belt that can fit large diameter and odd shaped things.
If that doesn't fit then you can resort to drilling the hole. Order a new cap first.
Old 10-09-2012, 12:28 PM   #6
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Vice grips would probably be my first go to tool for removing the stripped cap. A strap wrench if you have one handy would probably do the trick as well and be a little less destructive.
