Old 10-08-2012, 06:18 AM   #1
Sample011
My Ride: 330Ci E46
Question Connect angel eyes to fog lights?
Hello everyone. I got blue angel eyes for my E46 few months ago, and because of the colour i've been having problems with police, even got defected 3 weeks ago. To avoid this problem in future i want to be able to switch my angel eyes on and off indepenently to low beam lights. The best idea I could come up with is to connect them to fog lights switch, because i like my fogs on as well. Has anyone done it before?
PS. did some research couldn't find any clear explanation...(
Sample011 is offline   Reply With Quote
Old 10-08-2012, 06:37 AM   #2
fgin
My Ride: e46 facelift
should be easy to just hook it upto a fog light
fgin is offline   Reply With Quote
Old 10-08-2012, 06:43 AM   #3
Sample011
My Ride: 330Ci E46
So i just strip fog light wires and connect positive to positive, negative to negative without disconnecting fog light, then put some tape to isolate them? would it have enough woltage to run both lights(AE+fog light) off the same wire?
PS. really bad with electronics, haven't done much before, but want to learn...
Old 10-08-2012, 06:55 AM   #4
fgin
That should work. Insulate well.
Old 10-08-2012, 07:16 AM   #5
Sample011
My Ride: 330Ci E46
Thx for that, will try tmrow)
Old 10-08-2012, 04:13 PM   #6
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Blue? Really?! This the guy with the orange and drift damage?
E46 Coupe is offline   Reply With Quote
Old 10-08-2012, 06:01 PM   #7
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
^ they're like "MTech bulb blue"
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 10-08-2012, 06:59 PM   #8
steve.k
My Ride: 05' 325Ci, 13' WRX
Get normal coloured AE's and give the blues to YGO - it will go well with fanta
steve.k is offline   Reply With Quote
Old 10-08-2012, 08:38 PM   #9
Sample011
My Ride: 330Ci E46
Yeah, got them as a present, but will probably change them to orange or white at some point... Blue on orange looks a bit... Japanese to me
Old 10-08-2012, 09:17 PM   #10
YGOAMG
you obviously havnt seen OP's car
looks something a little like:
@PeterMarquez346
who da F done that?
Old 10-08-2012, 10:50 PM   #11
Chewy
My Ride: '03 LSB M3 Vert SMG
Nah pretty sure I'm buying ygo multi coloured halos for Christmas.
Chewy is offline   Reply With Quote
Old 10-08-2012, 11:14 PM   #12
DesiredM
My Ride: E46 M3
You know if your fog lights are on when they aren't needed you will get fined for that anyway?? If I were you I'd create a separate kill switch for them in the car if you really wanted to run them...or just wait and get normal ones and install them the normal way?
DesiredM is offline   Reply With Quote
Old 10-08-2012, 11:40 PM   #13
Sample011
My Ride: 330Ci E46
Well, if I wire them up to fog lights I can turn them both on/off when needed, cuz they are both illegal apparently, so I'll probably do that. Got too many fines ATM and I'm still at school, so can't afford any mods ATM...(
Old 10-09-2012, 04:40 AM   #14
CSL323
My Ride: 330Ci
Might be a better idea like DesiredM said to make a separate switch control your ae's... That is unless you plan to not have foglights anymore... And in the process you can give me the plastic covers that belong around the foggies.
This would be perfect for you if you had a CSL front.
CSL323 is offline   Reply With Quote
Old 10-09-2012, 07:37 AM   #15
Sample011
My Ride: 330Ci E46
From what i've found separate switches are pretty complicated to make. I'd definitely do it if i knew how to.
I was planning on leaving fogs as well, and turn fog light and ae's from the same button, just don't know if it's gonna work (
Old 10-09-2012, 03:49 PM   #16
YGOAMG
What is the "separate" switch you f4gs are talking about??
That's what his trying to achieve.. Using the fog light button as the AE on/off switch..
Why would you need ANOTHER switch?
@PeterMarquez346
who da F done that?
Old 10-09-2012, 03:59 PM   #17
steve.k
It's better to create a separate switch just for the AEs so that everytime he wants his AEs on he doesn't have to have the fogs on!
And since the AEs are blue you want to be able to turn them off when you see police without turning off your headlights..
Old 10-09-2012, 04:28 PM   #18
YGOAMG
Bold1:
Ye i guess ... but... eh
Bold2:
what will happen if you press the Fog button.. Headlights will stay on, AE's and Fogs off?
@PeterMarquez346
who da F done that?
Old 10-09-2012, 04:53 PM   #19
steve.k
I think being able to wire them up to some form of power source (fogs) but then using them on a separate switch... ie. the fogs can still be turned on/off and the AEs are not affected by this cause they are on their own switch kind of thing
If it were me i'd just change them to normal AE's and call it a day
Old 10-09-2012, 05:04 PM   #20
///MPR77
My Ride: 02 ///M3 Tri-Ped
Yes it will work fine, i did this when I had my CSL bumper, because no fog lights.
You will have to switch on your corner running lights to get the fogs/AE's to come on though.
