Old 12-21-2011, 10:30 PM   #1
Jay146992
My Ride: E90 335i & E46 M3
Stick shift sticking
I have a 2003 330i 5spd and for some reason the shifter does not stay in the middle when in neutral anymore. It stays to the right like it's stuck and doesn't pop back in the middle. For example, to put the car in 5th gear, all I have to do is push the shifter straight up instead of right and then up. How do I fix this?
Also, I want to put a short shifter in my car. What is the best short shifter I can buy?
Thanks in advance!
Jay146992 is offline   Reply With Quote
Old 12-21-2011, 10:37 PM   #2
moiz21
My Ride: 1999 323i 5-SPD
http://forum.e46fanatics.com/showthread.php?t=763236
Read this thread. There are other links within that lead to other threads on the same subject. Should find everything you need. I'm actually going with the 545i shifter. Going to pick it up tomorrow or Friday. Already paid for, just a matter of making time to make the trip to go pick it up.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 12-21-2011, 10:37 PM   #3
Trashcan
My Ride: 2002 330ci
I have the same problem, only sometimes though. It makes down shifting sketchy
Sent from my ADR6300 using Bimmer
Trashcan is offline   Reply With Quote
Old 12-21-2011, 10:46 PM   #4
98navi0314
My Ride: 02 330ci TiAg
I had this issue a few days ago. After a few minutes of driving, it went away....didn't think much of it, actually forgot till I read this thread.
Thanks for the link
98navi0314 is offline   Reply With Quote
Old 12-22-2011, 08:19 AM   #5
Hammer432
My Ride: 2001 330i 3 pedals
The sticking 5th gear position is a common problem. Mine does this when cold but frees up after 5 minutes of driving. I has to do with some pins and bushings in the transmission. Unfortunately the transmission has to be out to properly repair this. I will wait until I need a clutch. I doubt a short shifter will have any affect. See:
http://www.ex-parrot.com/pdw/mcoupe/...fix/index.html
Hammer432 is offline   Reply With Quote
Old 12-22-2011, 08:34 AM   #6
Bemwe_03i
My Ride: 2003.5 E46 M3 smg IR
So there's problems with the manual as well? should've gotten and auto ...
Bemwe_03i is offline   Reply With Quote
Old 12-22-2011, 09:21 AM   #7
Hammer432
No way!
Old 12-22-2011, 10:47 AM   #8
lsteg
My Ride: 2001 330ci
lsteg is offline   Reply With Quote
Old 12-22-2011, 11:55 AM   #9
Trashcan
My Ride: 2002 330ci
Old 12-22-2011, 12:45 PM   #10
SPDSKTR
My Ride: E46 ZHP TS2+ Coupe
A short shift kit will NOT fix this problem. Ask me how I know.
I just deal with it for now. I can't say I've ever had a bad shift when it's leaning. After the car warms up, it's fine and will "pop" back into place.
Originally Posted by Brucifer325 View Post
Thread sucks so bad they moved it to the Feedback Forum.
SPDSKTR is offline   Reply With Quote
Old 12-22-2011, 01:00 PM   #11
trizzuth
My Ride: 231k, 16yr old B3AST
YUP, thank the heavens I had this fixed when I was still under CPO warranty, must have been a $1500 bill at least, just to replace a 6$ bushing set! Scared mine feels sort of like it wants to start sticking again.. UG. what a horrific design to have something like this happen that involves so much work to fix!
short shift kits will do NOTHING to correct this, almost make it worse since the shift points are closer and you are more prone to tossing it into the wrong gear..
trizzuth is offline   Reply With Quote
Old 12-22-2011, 01:04 PM   #12
chsu74
My Ride: 550XI,993TT,GL320
I just had this fixed. Reason for the sticking is because the pin is made out of a different metal than the tranny case. Different metal have different rates of contraction tolerances under current cold temperatures. The fix replaces the metal pin with the same type of metal thus solving the problem . When the engine is warm, the tolerances are the same and no more sticking. I filled this with 3 different types of gear oil and never worked until now.
chsu74 is offline   Reply With Quote
Old 12-22-2011, 01:45 PM   #13
kbsilver
My Ride: 2000 328i
Yes that is exactly correct. An easy and inexpensive fix that can be done from outside the transmission. The little problem is the trans must be removed from the car to get access!
This has been occurring since around '98 when this ZFtrans was first used in the M3. Was solved when the E90 came out.
In almost all cases problem goes away once the trans warms up and is definately worse in colder weather. Simple fix is not use 5th gear until the trans is warmed (about 10 miles on a very cold day). Otherwise just be careful shifting until the problem clears.
I had this problem which started at about 60K miles, after the warranty was expired. My intention was to wait until the car needed a clutch and do it then. But I was told that the detent piston would eventually wear enough and the problem would cure itself. Sure enough at about 120K miles the problem did go away! We're at 145K and am still waiting to replace the clutch
kbsilver is offline   Reply With Quote
Old 12-22-2011, 02:29 PM   #14
Hammer432
I like the sound of that, I am at 103K miles and do mostly highway and rural driving and don't expect to need a clutch anytime soon! I just deal with it anyway, not a big deal.
Old 12-22-2011, 02:39 PM   #15
Brinkley
My Ride: 99 328i, 07 z4 3.0
yea, it's a little annoying, but one gets used to it. I have a UUC ssk, but still have this issue, definitely worse in the cold but always goes away after awhile.
Brinkley is offline   Reply With Quote
Old 12-22-2011, 04:17 PM   #16
iansanderson
My Ride: 2001 330CiC
I did the shift pin service over the summer. It is not easy and not fun. You absolutely must rent the special tools to do the pins and linings. If anyone here is going to do it, PM me and I will post the information of the guy that rents the shift pin tools and mails them to you.
Best thing is to have an assistant, a lift and a really good air-driven impact gun with a ton of extensions.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 12-22-2011, 06:06 PM   #17
Jay146992
I guess I'll wait until the clutch goes to fix that sticking problem then. 265k on original clutch I still want a short shifter though.
What do you think of this shifter? http://www.ebay.com/itm/270740517772...84.m1423.l2649.
Another thing is that my car doesn't ride that well anymore, as it has 265k miles. I'd like to completely replace the suspension. What all do you think needs replaced and do you recommend replacing with aftermarket or OE BMW parts?
Old 12-22-2011, 07:08 PM   #18
98navi0314
I have the B&M Hurst SSK. It was already installed when I bought the car used so I have nothing to compare to. All I can say is one less mod I would have to do.
Old 12-22-2011, 08:55 PM   #19
My325XI
My Ride: 03 325XI Sprt Prem
New rear shocks/mounts, new front struts/mounts, and at 265K new springs all around too.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 12-28-2011, 11:14 AM   #20
hummer
My Ride: 2001 330CI
Mine fixed itself when I changed to a real manual oil, Redline MTL. Some say no because the tranny was designed by BMW to operate on ATF type oil. BS! they missed something in the design then. If you believe the BMW BS about lifetime fluid and don't change the oil regularly, your tranny is going to suffer.
