Sponsored by BimmerWorld
Old 10-08-2012, 05:59 PM   #1
bmwcanman
My Ride: 2004 330ci m-sport
Rear Bushing Kit Sizes?
I'm looking to do my entire rear suspension including all bushings (ie. upper and lower control arms, RTAB, and subframe). I see there is a specific BMW kit for this work, but they are very expensive. I assume any bushing press kit will work...unless BMW is special? If it is possible to use any bushing press kit, does anyone know the sizes I will need to complete the work?
bmwcanman is offline   Reply With Quote
Old 10-11-2012, 06:13 AM   #2
lucky_doggg7
My Ride: 2005 M3
Here you go:
Rear Suspension Refresh Kit - Level 2
BMW E46 330Ci M54 3.0L*
Kit for a more complete rear suspension rebuild using OEM components
Level 2 rear suspension refresh kit addresses failure of the rear subframe bushings, rear trailing arm bushings, and rear control arm bushings.
Symptoms include a loose feel in the rear end under hard acceleration, as well as side to side wandering of the rear end between shifts under hard acceleration. Other symptoms include clunking over bumps, severe vibration at speed, and excessive tramlining. If your vehicle is receiving a subframe mount reinforcement installation, this is the ideal bushing kit to complement the work.
http://www.ecstuning.com/BMW-E46-330...ts/ES2219641/#
With the proper tools, replacement of these components will take approximately 1 day.
Kit content includes:
Rear subframe bushings
Subframe bushings
Rear differential bushings
Control arm bushings
Trailing arm bushing
Rear strut mounts
Reinforcement plates
Rear swaybar links
All the necessary bolts, screws and nuts
See Kit Contents for specifics.
<< Read less
Ships in 1-3 days
$672.95
Product Info
Mfg Part#33326770824
ECS Part#ES#2219641
Brand
Track and Share
Application GuideKit Contents
Description Brand Qty
Rear Subframe Bushing - Front Left 1
Rear Subframe Bolt - Priced Each 2
Rear Subframe Nut - Priced Each 2
Rear Subframe Bushing - Priced Each 2
Front Differential Bushing - Priced Each 2
Hex Bolt 2
Rear Differential Carrier Bushing 1
HEX BOLT 1
Rear Subframe Bushing - Front Right 1
Control Arm Bushing - Priced Each 2
HEX BOLT 2
LOCK PLATE 2
Rear Control Arm Bushing - Priced Each 2
Hex Bolt With Washer 2
Self-Locking Nut - Priced Each 8
Trailing Arm Bushing - Priced Each 2
COLLAR SCREW 2
Camber Adjustment Eccentric Bolt 2
Trailing Arm Ball Joint - Priced Each 2
HEX BOLT WITH WASHER 2
Rear Reinforcement Plate 2
Rear Strut Mount - Priced Each 2
Rear Sway Bar End Link - Priced Each
Last edited by lucky_doggg7; 10-11-2012 at 06:14 AM. Reason: Include website to buy parts.
bushing, kit, press, rear, size
