Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
How do I find which bearing is bad
Is there a trouble shooting way or a specific method to finding out which wheel bearing is bad ?
#2 |
Yes there is, when you turn left it loads up the right side when you turn right it loads up the left side, so take a left and right turn, if its louder when turning left it's on the right and if it's louder when turning right is on the left. Then when you figure or what side it's on jack that side up and shake the wheel. One hand on top of wheel one on bottom and try to move it back and forth. So push on top of wheel and pull on bottom, and do that repetitively. If there's movement it's bad. there shouldn't be any moment.
Sent from my DROID RAZR using Bimmer App |
#3 |
You able to fine the culprit?
#4 |
Not yet man I just got to work but I will as soon as I can
Thanks for the advice braahh
#5 |
Yep your welcome man, good luck with trying to find it
#6 |
I found a nicely priced kit (40$ for both) but not sure about the fitment as is says it will fit m3 z3 318 not sure if it ll fit mine 2002 325
#7 |
Here is the description
#8 |
Anyone ?
#9 |
Really don't wanna make another thread to see if the bearing in the pic is compatible
