Old 10-09-2012, 07:53 PM   #1
Qualengpro
My Ride: 2003 330xi
Auto leveling motor for bi-xenon headlights?
I have a 2003 330xi that recently developed the dreaded "droopy eyes" at start-up. I have verified that the front leveling sensor is connected OK....and had a local shop (that specializes in BMWs) run a computer test. They tell me that I need to replace my driver's side headlight assembly for about $1,300. ....I should back up and explain that when I start the car, the lights go through their initial leveling test....but don't return to the "normal" setting....so my lights don't point far enough down the road...they only shine about 40 feet (on low beam) in front of the car. Both lights do the same thing...one side is not higher than the other. I am told that the computer is "holding back" the right side because of the binding on the left side. Does that make sense? I am suspecting that the leveling motor is gone, and I am trying to see if anyone on here knows where I can get one. Thanks for your help in advance.
Qualengpro is offline   Reply With Quote
Old 10-09-2012, 11:23 PM   #2
Cyanide72
My Ride: 2002 325i
This exact same thing happened to me last week. I had the car inspected at two different places that specialize in BMWs, both told me the motors in the lights themselves were on their way out due to corrosion and that later on down the road I'll need to replace both headlight assemblies. I then took the car to my indy mech and I've no idea what he did but the lights are working just fine now, auto level and all. My guess is he did something to remove the corrosion in the lights or something.
As for the part required, have a look around at http://www.realoem.com/bmw/select.do
Unfortunately, I don't know the part that you (and I for that matter) need, but I'm sure someone more knowledgeable than me will come along and provide you with the correct details.
Cyanide72 is offline   Reply With Quote
Old 10-10-2012, 09:31 AM   #3
Qualengpro
My Ride: 2003 330xi
Thanks for your input...too bad your mechanic didn't tell you what he did! It could do two things...1.) help others with the same problem, and 2.) give you a heads up if his repair was just a temporary one. I will check out your link....thanks for the help!
Old 10-10-2012, 12:01 PM   #4
Qualengpro
My Ride: 2003 330xi
Arrow bi-xenon front level sensor position?
As I have said in this thread, I am having a problem with my bi-xenon headlights not auto leveling correctly. At start-up they go down as normal, but only go "up" approximately half way. Consequently, my headlights (both of them) point too low and my night visibility is restricted, especially on low beam. After searching the threads, I am wondering if my BMW technician inadvertently hit the connecting link on the front level sensor and knocked it out of position. I have seen similar threads saying the sensor arm should be "up" and not "down". But, no photos were attached to indicate what "up" means. This link seems to indicate that the sensor arm should be horizontal: http://www.realoem.com/bmw/showparts...67&hg=31&fg=05
Can anyone out there verify to me if mine is correct, or if it got re-positioned during either a CV joint inspection, or the actual replacement later (which you can see in the photo)?? Thanks!!
Name:	2003 330xi front level sensor 03.jpg
Old 10-10-2012, 02:26 PM   #5
toy4to
My Ride: 2004 M3 AA Gen6 1.5
Easiest thing: set your vertical and horizontal aim, and then disconnect the stupid auto leveling. It's not needed.
toy4to is offline   Reply With Quote
Old 10-10-2012, 05:04 PM   #6
Qualengpro
My Ride: 2003 330xi
Talking
I think I've solved the problem! I took your advice and disconnected the lower linkage arm bracket from the lower suspension arm and flipped it around so that the sensor arm itself is more-or-less horizontal as you can see in the photo. It seems to have cured the problem, but I won't know for sure until it's dark and take the car for a test drive. Thanks for all of your help!
Name:	After changing sensor arm orientation 02.jpg
Old 10-11-2012, 11:26 AM   #7
Qualengpro
My Ride: 2003 330xi
Update: The changing of the level sensor arm to "horizontal" seems to have fixed the problem! I took it out for a test drive last night, and all seems back to normal! I can see again! Why would any technician that normally works on BMWs not know that this should be the FIRST thing to check when someone comes in with this problem? It can't be that uncommon...and when both lights are doing exactly the same thing, wouldn't you normally assume that the problem is somewhere in the system that controls BOTH lights, as opposed to thinking only ONE light assembly is broken? sheesh!
Old 10-18-2013, 03:00 PM   #8
330XIBimmerguy
My Ride: 330XI 2002
I had my axles replaced and the same thing happened to my headlights just like Qualengpro. The tech must have hit the auto level sensor arm and never re adjusted it. Damn you think techs would watch for this, with this happening I guess there is a reason why I do almost all the work on my car myself. Thank you Qualengro and fellow E46 fanatics.
Cory.
330XIBimmerguy is offline   Reply With Quote
Old 10-18-2013, 03:22 PM   #9
DonaldE
My Ride: 2002 330i
Yeah, there is no possibility of corrosion inside the headlight assembly for the record. I've had both motors out of my headlights and there is no way water could get in there to cause corrosion
Furthermore it's a magnetically adjusted motor.
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
Old 01-11-2015, 06:05 PM   #10
Bbach85
My Ride: 2004 330xi
Thank you so much for this thread. I was driving around for 2 years with my headlights pointing down. Had my axles replaced by a a shop (who I still stand by as a great mechanic) but must have not put the sensor back together properly. Brought it to several shops for second opinions and nobody had a clue what was going on. I don't think it is necessarily an issue of "bumping" the sensor but there are two options of how to put the sensor linkage back together either vertical or horizontal. If they put it back together so it is vertical it is incorrect and the headlights will not function. Flipped it back as described above and my headlights are awesome again.
Bbach85 is offline   Reply With Quote
Old 01-12-2015, 04:03 PM   #11
Qualengpro
My Ride: 2003 330xi
I had this happen twice at the same shop....even after I told them about the issue before the second axle replacement. I saw no evidence that they disconnected the position sensor link....I think that when they disassemble the axle and wheel assembly, the wheel is then free enough to allow the link arm to swing past "center" and end up on the wrong side.....and that is why they miss it....they don't disconnect it....so they aren't thinking about it. Either way, it's fairly easy to fix (even in a parking lot!)....and seeing is much improved! I am glad the post helped. This web site has been a great source of good support and info for me. Makes owning my beemer even more enjoyable!
