Old 10-11-2012, 10:48 AM   #1
Diazz
My Ride: Bmw 325Ci -01
Bootlid handle does not work?
Hey guys!
The button onthe handle doesnt work, nor does the license plate light :/
I can open the lid with the button on the key, so the motor works. Has anyone had the same problem?
Thought i'd check in with you before i start tearing my car down to pieces
Thanks!
Diazz is offline   Reply With Quote
Old 10-11-2012, 03:07 PM   #2
MrEmitter
My Ride: 2002 330ci
I have the same problem. The button under the dash doesn't work either
MrEmitter is offline   Reply With Quote
Old 10-11-2012, 03:42 PM   #3
cityjohn
My Ride: 2001 M3
Look inside the rubber hose connecting your bootlid to car body. Inside are a dozen wires that break from the folding stress; once they break they start shorting and causing the problems you describe.
cityjohn is offline   Reply With Quote
Old 10-11-2012, 03:48 PM   #4
LD330XI
My Ride: '09 335i
My guess is the wiring as stated above, or that your key lock on the trunk itself is horizontal. It will disable the buttons when it is flat. That means that the only way in is with a real key or a fob. Keeps the valets out.
LD330XI is offline   Reply With Quote
