Old 10-28-2013, 12:59 PM   #1
94jedi
My Ride: 2003 330i ZHP
Heater not working?
Hey all, as the title states, my heater is blowing ambient temp air, maybe even "warm" air but doesn't get hot at all even after the car reaches normal operating temp.
No CEL's, no changes, car temp is fine etc. It blew hot air last week no prob, just this morning is when the issue started.
I did some searching/reading and it looks like the heater control valve may be the culprit.
Any thoughts? Thanks!
94jedi is offline   Reply With Quote
Old 10-28-2013, 01:01 PM   #2
Chaplian
My Ride: M56 SULEV
Could also possibly be the thermostat. How many miles does your car have and did you ever overhaul the cooling system?
Chaplian is offline   Reply With Quote
Old 10-28-2013, 01:21 PM   #3
94jedi
92,500 and no cooling system overhaul yet - It's on the "to do" list.
Old 10-28-2013, 01:29 PM   #4
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Heater not working?
At that mileage I'm betting bad thermostat. Check your coolant temp via the OBC display and report back.
Old 10-28-2013, 02:03 PM   #5
Hamsocne
My Ride: 2002 330Ci
I would guess the therm, too.
I was not on this site for my first 02 e46 and at 90,000 plus I cannot find where any cooling system work was done, I didn't know better and owned it from 60k to 90k. I have all the records and looked.
On this 02 the therm was replaced by the previous owner at 38,000 miles. I have done the rest of the cooling system minus the radiator and am at 72,000.
It is so nice to have these records. I doubt this helps. Go to JFOJ's link about soft fails. Access the temp and see.
Hamsocne is offline   Reply With Quote
Old 10-28-2013, 02:20 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
3rd link below in my signature.
Bring up the Hidden OBC Menu and watch the engine temp on your OBC/Dash.
You should come up to about 95-96C and stay there.
Also check for low coolant and air in the system.
BE CAREFUL, do not fill the expansion tank up much, make sure the float is on t low side if the temp is below 68F.
Hit the Fractured Prune & Dumser's for me while your at it!
Old 10-28-2013, 02:22 PM   #7
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Outback
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
I get a steady 97 C in the garage sitting still at 5500 rpm
VALMONT is offline   Reply With Quote
Old 10-28-2013, 02:23 PM   #8
94jedi
Thanks for the tip! I'm searching for the "how to" for pulling up the hidden OBC menu.
If I can get my heat working without blowing a lot of $ on a fix, then Dumser's is on me next time you're down here lol.
Old 10-28-2013, 02:32 PM   #9
jfoj
Also check YouTube for the Hidden Menu, the issue is it is all about timing of button pushing, my E39 is FAR easier to access than the E46!
