Wheels and Tires
Old 10-10-2012, 11:29 AM   #1
J-SON
My Ride: (2)2002 Volvo V70XC
17" XXR 522 Wheels w/extra tires - 17x9 - $550
CL Ad: XXR 522 CL Ad
Selling my XXR522 wheels. They have a set of Kumho tires on them now, but will need to be replaced within the next season or so depending on how your vehicle is. They will be sold with an extra set of tires of the same size - Goodyear Eagle.
LOCAL pickup ONLY - Located in Schenectady, NY area.
Specs on the wheels and tires can be found below:
Wheels Specs:
Brand: XXR
Style: 522
Color: Black Chrome
ET (Offset): +25mm
Lug Patterns: 5x120 and 5x114.3
Will fit most Honda, Acura, BMW, Mitsubishi vehicles. Please verify your lug pattern and that these wheels will fit your car due to the width and higher offset.
Tire Specs:
Kumho Ecsta ASX - 235/45R17
Goodyear Eagle - 235/45R17
Please call Five One Eight - 928/6704
current rides (my wife and I):
(2) 2002 Volvo V70 XC Cross Country Wagons, 1985 Buick Regal Grand National, My Desk
J-SON is offline   Reply With Quote
Old 10-11-2012, 08:03 AM   #2
J-SON
bump
Old 10-12-2012, 08:09 AM   #3
J-SON
AM Bump
Old 10-22-2012, 08:01 AM   #4
J-SON
Sold
Old 10-25-2012, 06:44 PM   #5
limpiabota809
My Ride: 330 XI
when you ran these were they pretty squared? or ran something like oem?
limpiabota809 is online now   Reply With Quote
Old 10-26-2012, 08:01 AM   #6
J-SON
I'm not quite sure what you mean, but I ran a square setup of tire size with factory alignment setting for toe, but the camber was waaaaay out because I had the car slammed. The rear toe was a little out because the factory adjustment wasn't there.
After it was all adjusted it was pretty good on wear. It rode pretty smooth, but coming from the balloon tires (195/65/15) it was a pretty stiff ride in comparison.
The rear fender wells were trimmed and pulled out hard (this required body work after the pull because there was LOTS of broken paint and bare metal) to get clearance for the tires (235/45R17) that I had on there, but it still hit the inner part of the fender well way up in the wheel well. I would recommend just getting a smaller tire like a 225, 215, or a 205 to run stretched on a 9" wide wheel with +25mm offset.
Hopefully I hit your question somewhere in this shotgun blast of an answer.
17x9, 235, 522, wheels, xxr
