Old 10-10-2012, 04:50 PM   #1
DjZHP
My Ride: 03 330i
Odd electrical reaction
Put in a pair of HIDs into my fogs a few months ago. This "issue" never bothered me, but I was just curious of what could be causing the hi beam indicator on the dash to quickly flash at the same time I turn the fog lights on.
Like I said, not a problem nor does it bother me, but just curious to see if they're wired in together somewhere in the electrical circuit.
DjZHP is offline   Reply With Quote
Old 10-10-2012, 04:51 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
LCM is not designed to handle xenon fogs, nevertheless without a wiring harness. Take that crap out before your fry a lot of things on your car.
Old 02-06-2013, 11:58 AM   #3
DjZHP
My Ride: 03 330i
Ordered a whole new kit from DDM tuning with the wiring harnesses. Problem solved!!
Instructions::
Connect #4 and #5 to HID ballast
Connect #1 to battery positive
Connect #2 and #3 to ground
Connect #6 to stock harness or the wiring from the HID bulb and then to stock harness
Some harnesses some vary, but this is which wires are used...
-Power
-Ground
-Two male plugs to ballast
-One female to ONE factory wire, if the harness comes with an extra just tape it off.
Old 02-06-2013, 06:00 PM   #4
christiandflores
My Ride: BMW M3 E46
So in total it's only one harness you need and you will connect it to only one OEM foglight connector and leave the other one disconnected? I've been having the highs flag too.
- Christian
BMW M3 E46 | Carbon Black Metallic | Gray Nappa | 6MT | SMG | 40% Tint | Full LED Interior/Exterior | Michelin PSS 275/30/19 square set up
https://www.facebook.com/SanDiegoBmwMeet
christiandflores is offline   Reply With Quote
Old 02-06-2013, 09:51 PM   #5
DonaldE
My Ride: 2002 330i
Yes
DonaldE is offline   Reply With Quote
Old 02-06-2013, 10:33 PM   #6
DjZHP
My Ride: 03 330i
Leave either #4 or 5 taped off on each side. You will need two wiring harnesses.
