Sponsored by BimmerWorld
Old 10-18-2012, 10:53 PM   #1
SA Justin
My Ride: 09 G8 GT, e46
Wtf???
I just changed my tie rods, front control arms/bushings, and sway bar end links. I knew I was going to need an alignment anyway and Firestone is a couple blocks away so I just ball parked the tie rod lengths.
I went to drive the car and the friggin steering wheel is now facing 90 degrees toward the passenger side when I drive straight. I was expecting jack up alignment, but is it normal for the steering wheel to be so far misaligned? I'm afraid I might have messed something up with all that pickle fork persuasion....
Thanks in advance for your help!
SA Justin is offline   Reply With Quote
Old 10-18-2012, 11:14 PM   #2
SA Justin
I left it at Firestone and they'll do the alignment in the morning. Do you think they'll fix the off-center steering wheel too?
Old 10-18-2012, 11:26 PM   #3
///MPR77
My Ride: 02 ///M3 Tri-Ped
The steering wheel adjustment is part of the alignment.
Curious, did you have the old , and new tie rods side by side when you adjusted them?
Old 10-18-2012, 11:35 PM   #4
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
that's normal. mine was totally like that too when i thought i had them adjusted close to the old ones.
even a couple of threads will turn your steering wheel pretty far.
they'll correct it when getting it aligned.
Old 10-19-2012, 12:19 AM   #5
///MPR77
^ good to know. I have a new set in the trunk that I plan on doing this weekend.
Old 10-19-2012, 01:12 AM   #6
SA Justin
Yeah but I just quickly eyeballed it. Didn't think it would matter much since I was only drive a few hundred feet before the alignment.
Old 10-19-2012, 01:13 AM   #7
SA Justin
Ok. Good to know. I was a little freaked out by how far off it was...
Old 10-19-2012, 01:25 AM   #8
peytonracer4
:D
My Ride: '00 328i
Trust me I was too at first. Haha.
