Sponsored by BimmerWorld
Old 10-11-2012, 01:03 AM   #1
mrbcc
My Ride: Silver 330i
What extra parts do I need for suspension refresh
Just ordered koni yellows and some springs... what do I need to complete the install (not tools, just parts)?
Do I need these?
http://www.turnermotorsport.com/show...e46-z3-z4-pair
Or tower reinforcement plates??
http://store.bimmerworld.com/e36e46e...tes-p1219.aspx
if I can safely re-use parts (nothing I can see is cracked) then I will, no need to throw parts at it if I don't need to.
mrbcc is offline   Reply With Quote
Old 10-11-2012, 08:47 AM   #2
euG!
My Ride: ZHP SALOON
Send a message via AIM to euG!
The front reinforcement plates are not necessary but gives a piece of mind. Also get:
New FSM's (I only advise this because if/when they do go bad you have to uninstall your entire front suspension and pay for another alignment)
RSM gaskets
RSM Z3 reinforcement plates
And maybe all new nuts (not necessary but i like to have never been torqued nuts, plus it's cheap)
You could wait on the RSM's. They are easy to replace later down the road and don't require another alignment so I would hold off if they're not bad.
'04 330i ZHP
TiAg/Alcantara
3.46/APEX/KONI/COBY/JAFFSTER
euG! is offline   Reply With Quote
Old 10-11-2012, 10:00 AM   #3
mrbcc
Maybe just get this and be done with it?
http://www.turnermotorsport.com/p-11...m3-not-xi.aspx
RSM gaskets
Old 10-11-2012, 07:01 PM   #4
euG!
My Ride: ZHP SALOON
Looks good
'04 330i ZHP
TiAg/Alcantara
Old 10-12-2012, 09:14 AM   #5
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Guys, I'm not sure about that "repair shop" rear shock upper mount:
The design looks pretty far off from the original part. For about the same price you can get Sachs or Meyle HD strut mounts. For a little more you can get the Genuine BMW mounts.
http://www.ecstuning.com/BMW-E46-330...n/Shocks/Rear/
As far as other hardware, like euG! mentioned you will need to replace all the following:
2 front strut pinch bolts
6 front strut self-locking tower mouting nuts
2 front strut self-locking shaft nuts (if not already included with the Konis)
2 rear shock self-locking shaft nuts (if not already included with the Konis)
2 rear shock lower mounting bolts
4 rear shock self-locking upper mount nuts
2 rear shock upper mount gaskets
May or may not need, depending on condition:
foam bump stops
rubber boots for front struts
rubber spring pads for front struts
plastic boots for rear shocks
I usually consider reinforcement plates optional for daily driving, but since you are installing a stiffer aftermarket suspension it might be a good idea. Get the rear reinforcement plates, too.
Old 10-15-2012, 11:30 PM   #6
mrbcc
This list helps a ton LeMansteve and euG! Here is what I ended up with:
$250 later....this is expensive! almost 1/2 the price for the struts/shocks for mounting hardware...jeez (end btch session)
foam bump stops
Old 10-26-2012, 10:22 AM   #7
LeMansteve
Indeed. If you replace all the hardware, pads, mounts, etc it really does add up. When I bought parts to replace my shocks and struts, I was surprised how expensive the molded foam bump stops are.
Old 10-31-2012, 12:31 PM   #8
Platano20
My Ride: e46 3-Series
foam bump stops
Hey guys. I am in the same process so I was wondering why you recommend getting new "front strut pinch bolts" and "rear shock lower mounting bolts". Just wondering what the reason is as its not the first time I have read this recommendation.
So far I have this :
Hope you don't mind me hopping on this thread also as I'm doing the same for my 2000 328Ci AT sport suspension. So far waiting for delivery I have:
Koni FSD's (Modbargains)
Eibach front and rear sway bars (Tire rack)
Front & rear sway end links (meyle hd)
Eibach pro-kit springs
Coil spring pads
Rear bump stops (sport)
Dust boots
Front & rear reinforcement plates (ECS Tuning)
Front and rear strut mounts (Sachs)
**** wasn't cheap smh... (wish I knew how to insert those smileys)
I also am wondering if I'm missing something.
Myself: Upper/Lower Intake Boots, Head Light Lenses, Kicker L5 12" Sub, Tints 18% all around, smoked corners & side markers, Spark Plugs, Front Eibach front & rear Sway Bars, Front & rear Sway Bar End Links, Eibach Pro Springs, Koni FSD Struts & Shocks, Meyele HD Front Control Arms and Bushings,
Platano20 is offline   Reply With Quote
Old 11-06-2012, 02:10 PM   #9
LeMansteve
It's my personal preference to get new hardware, especially if it is relatively cheap. I don't think these two bolts are torque-to-yield, but suspension fasteners generally take a beating and I always prefer to replace them when doing a job.
