///M3 Forum
Old 10-11-2012, 12:04 PM   #1
aek427
My Ride: 2006 BMW M3 Conv.
Am I getting ripped off by BMW?
I took my 2006 in to BMW for a regular oil change and fluid top off at 35k and they said the differential is leaking slightly and eventually it will become an issue.
They quoted $1,190 to fix the issue and it seems like a ridiculous amount for a minor issue...am I wrong?
Current Ride:
2006 M3 Convertible Carbon Black Metallic/Cinnamon
Previous Rides:
1995 325i Convertible Bright Red/Black
2003 Honda S2000 Spa Yellow/Black
2009 BMW 328i Coupe Jet Black/Black
2010 BMW 128i Coupe Jet Black/Tan
aek427 is offline   Reply With Quote
Old 10-11-2012, 12:08 PM   #2
n3985
My Ride: E92 soon?
You need to find out where the leak is from first, this changes the repair amount greatly.
n3985 is offline   Reply With Quote
Old 10-11-2012, 12:19 PM   #3
jhaurimn
My Ride: 01' 330ci
Diff seals are known to leak, however that price seems ridiculous. Find a reputable Indy shop and save a few hundred bucks
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 10-11-2012, 12:26 PM   #4
lucky_doggg7
My Ride: 2005 M3
At first blush, 1200 dollars doesn't seem out of line considering BMW shop labor rates hover around $140 per hour. Removing a diff from the carrier assembly, and axles is not exactly a 15 minute job. Like others have noted, call other dealers and indy shops to find the best price.
Old 10-11-2012, 01:42 PM   #5
taylor192
My Ride: 2003.5 M3
The dealer is going to be a ripoff for this, find a good independent.
There are 4 seals it could be leaking from, front (driveshaft), sides (axles), rear (cover).
The axle seals can be replaced easily without removing much:
http://www.bokchoys.com/differential/diy_diff.htm
The driveshaft and rear seals probably require pulling the whole differential:
Yet both of those look like 2-4hr jobs + parts/fluids, so $1200 sounds ridiculous unless the M3 diff seals are made of gold.
For reference, I had all the seals replaced on my Mercedes a few years ago for < $500 inc parts. To do that required pulling the axle shafts which is more involved than the M3 where they are just bolted on.
