///M3 Forum
Old 10-11-2012, 03:44 PM   #1
jmanhas
My Ride: BMW M3
Speedometer Delay
When I accelerate from a dead stop, the speedometer doesn't move until i hit 2.5-3k RPM..which is unusually slow. Just wondering what could be going wrong here?
I believe it might have to do with the speed sensor near the Right rear ABS sensor..
I just got my winter wheels mounted onto my rims, and when they put it back, could they have accidentally tampered with the sensor? causing a slight delay in the reading?
thanks for the help
jmanhas is offline   Reply With Quote
Old 10-12-2012, 12:01 AM   #2
illestminimike
My Ride: Project Drama
Do you have any lights on?
Old 10-12-2012, 04:23 PM   #3
jmanhas
My Ride: BMW M3
nope no lights on, everything looks normal..
when i changed my tires, i went from a 225 40 18, to a 245 40 18..
would that affect my speedometer that much?!
Old 10-13-2012, 06:14 PM   #4
NUe46///M
My Ride: 2003 E46 M3
It could be because the needle rests on 5mph...not zero.
2003 ///M3 TiAg, Black Leather, 6MT
CHICAGO, IL
NUe46///M is offline   Reply With Quote
Old 10-13-2012, 06:35 PM   #5
///MPR77
My Ride: 02 ///M3 Tri-Ped
OP,
Do the Cluster reset..
Specifically:
Menu 19 to unlock
Then
Menu 21 to reset.
All your gauges will cycle, and recalibrate.
Report back.
Old 10-13-2012, 08:21 PM   #6
NUe46///M
My car does it too. No need to reset...again, the needle rests at 5mph, not zero.
CHICAGO, IL
Old 10-14-2012, 02:04 AM   #7
jmanhas
My Ride: BMW M3
hmn.. my speedometer never did that tho, thats the weird part.
I'm going to try the cluster reset and let you know how it goes..
Old 10-14-2012, 11:54 AM   #8
ME46SM
My Ride: '04 E46 M3
keep us posted
ME46SM is offline   Reply With Quote
Old 10-18-2012, 03:59 PM   #9
jmanhas
My Ride: BMW M3
so i did a completely speedometer reset, where all the lights come on, and the gauges sweep.
and its back to normal now!
thanks for all the help
Old 10-18-2012, 04:12 PM   #10
///MPR77
Glad to help, thanks for the update.
Sent from my SAMSUNG-SGH-I727 using Bimmer App
Old 10-19-2012, 01:37 AM   #11
braymond141
My Ride: 96 M3, 02 M3, 01 M5
Originally Posted by ///MPR77 View Post
OP,
Specifically:
Menu 19 to unlock
Then
Menu 21 to reset.
Report back.
For the record. That is NOT a reset nor is it a recalibration. It is purely a visual function test, nothing more.
Any resolve from this has simply come from running the gauges through their sweep. A 180mph speed run would of done the same thing (just a point to prove that there is no recalibration procedure).
braymond141 is offline   Reply With Quote
Old 10-19-2012, 07:33 AM   #12
///MPR77
True, there is no comparative measurements, and tweaks while doing this, so I'm sorry that I used the word calibrate....perhaps exercise would have been a better choice.
As far as the reset....well you're incorrect. I assume you have done this, have you never noticed that
it does reset MPH, MPG predicted
range, and trip, well the trip gets reset because the stalk gets pressed to enter into the locked cluster menus...
Old 10-19-2012, 03:10 PM   #13
braymond141
I don't recall that being rolled into the visual function test. I'll have to go out and look later. These would be two different menu selections on the E36 and the E39 (which are the last two vehicles in my mind using these menus).
Old 10-19-2012, 06:36 PM   #14
///MPR77
Guaranteed, menu 21 resets all the previously mentioned parameters.
It has on my past three "3 series"
Years Ranging from 2000-2005
