Complete Cars
List your BMW or other cars, trucks or vehicles for sale. Don't forget to search for deals on craigslist and eBay Motors |
#1 |
FS: E36 Race Car NASA GTS3 'The Green Monster'
Selling this sorted and very fast race car.
![]() Engine: • S52B32 3.2L Engine • Refreshed Cylinder Head • Rebuilt VANOS System • Custom Camshafts • Custom Intake System • EPIC ECU Software • M50 Intake Manifold Conversion • Evosport Pulley System • European-Spec Exhaust Headers • VAC Baffled Oil Pan • Dual-Fuel Pump Setup • Custom Solid Motor Mounts (Motor Lowered 15 mm) • Custom Side-Exit Exhaust System • Custom Wiring Harness • Custom Triple-Pass Radiator • Braille Lightweight Battery Drivetrain: • 318/325 Getrag Transmission • AKG Motorsport Shifter • Quartermaster Twin-Plate 5.25" Racing Clutch w Floating release bearing • 3.73 Limited-Slip Differential (3-clutch) • 3.91 Limited-Slip Differential (4-clutch w/custom ramps) • Custom Solid Transmission Mounts Suspension/Steering: • MOTON 3-Way Adjustable Coilover Suspension System (Custom-Valved) • Ground Control Race Camber Plates • Ground Control Racing Swaybars • Ground Control Rear Control Arms • Custom Bump Steer Setup • Custom Heim-Jointed Outer Ball Joint & Front Control Arms • Custom Steering Column (Fully-Adjustable) • AKG Motorsport Front Control Arm Rear Brackets • AKG Motorsport Rear Shock Mounts • E36 M3 Steering Rack Brakes: • StopTech Big Front Brakes • StopTech 2-Piece Vented/Slotted Rotors • E36 M3 Rear Calipers • Vented Rear Brake Rotors • HAWK DTC-70/DTC-60 Brake Pads (90%+ Pad Left) • Custom Dual Master Cylinders Setup • TILTON Brake Bias System(knob on the dash) Wheels/Tires: • 3 Sets of Wheels & Tires: -Maxxim Wonder 18" x 8.5" w/Hoosier R6 225/40/18 Tires -Maxxim Wonder 18" x 8.5" w/Hoosier R6 225/40/18 Tires -ASA GT5 18" x 9.0" w/Hoosier A6 245/35/18 Tires Exterior/Aero: • Custom Front Splitter & Rear Wing • Custom Lexan Windows with Glass Windshield Interior/Electronics: • COBRA Evolution GT Race Seat • G-Force Pro Series Harnesses • Sparco Steering Wheel w/Quick Release • RacePak iQ3 Data System w/Oil Pressure & Fuel gauge • Carbon Fiber Switch Panel & Cluster Insert Safety: • Full Custom Rollcage • Rollcage Extends to Front Shock Tower & Rear Subframe • Integrated Strut bar • Full Fire Suppression System • Emergency Power Cutoff Switch Vital Statistics: • 2640 lbs. with 1/4 tank of gas & 200 lb. driver (Very Lightweight) • 239hp restricted Lap Times: Lime Rock Park: 58.3 Mid-Ohio: 1:36.9 NJMP Lightning: 1:12.0 NJMP Thunderbolt: 1:30.0 Pocono Long (Dbl. Infield) 1:36.2 Pocono North: 59.0 Summit Point: 1:21.1 Watkins Glen: 2:09.9 This car will be at NJMP on 10/27-10/28 come out and see it! PRICE IS $28,500 ![]() For more photos, check out our page on Facebook Some in-car Video Call (203) 220-9265 Email: hsmracing@aol.com Last edited by MrFukengruven; 10-11-2012 at 06:44 PM. |
#2 |
bump
#3 |
bump
#4 |
car just won the race in GTS3 at NJMP last week out of 12, very fast cars in class. Ran 1:29's at NJMP Thunderbolt w/o Chicane.
#5 |
bump
| Tags |
| bmw, e36, e36 m3, nasa, race car |
