Old 10-15-2012, 09:34 AM   #21
Sound Performance
Past Site Sponsor
Location: Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
My Ride: Is very FAST
Originally Posted by Forcefed M3 View Post
The S54 in my opinion is superior to the 2jz-gte. Both have the same amount of main bearings. Both have oil squirters and both are straight 6 motors. But to even get into the same horsepower level with the S54 head, the 2jz-gte would need head work. Just my $.02
I have to disagree somewhat. I have a car at the shop that is a 9.8-1 2J 3.4L and it made 950 rwhp with a 6766 and 1130 rwhp with a 7275 turbo. The car's head is stock except for kelford cams. The 2J is simple bullet proof in stock form up to 1000 crank HP and when built it has been engine dynoed well over 2000 hp. It has propelled many cars to low 6 second quarter miles and over 250 in the standing mile. The stock head / stock cam setup on the BMW does flow quite a bit better on the BMW though. I am not sure that anyone has really pushed the BMW engine with the proper parts. Maybe with a larger intercooler, bigger cams and a better exhaust manifold the BMW would prove superior? It certainly does outperform the 2J at lower boost levels but there seems to be a bottle neck somewhere. And don't forget that you do not have to sleeve the 2J block to handle high HP. Both are great motors though no doubt!
Sound Performance is offline   Reply With Quote
Old 10-15-2012, 09:43 AM   #22
E85head
My Ride: E46 M3
Originally Posted by dallasberry View Post
What he Said
What does it look like?
E85head is offline   Reply With Quote
Old 10-15-2012, 11:29 AM   #23
7to3_enthusiast
My Ride: '02 AW 6spd M3
Peak hp is nice but from your experience, which motors (at similar boost levels and similar sized turbos) have a larger power band and/or make more torque? I know there are a lot of other factors, but what would your opinion be? Ceteris paribus, 2jzs have always seemed like dyno queen motors or highway monsters. Not suitable for a worthy track car because the boost would come in relatively late and VERY hard making traction nearly impossible at low gears...correct me if I'm wrong.
94 VR R2 Rx7 SOLD
02 AW M3 The daily / looking for FI
14 CW 1.8T Beetle - Wife's dream car
02 4.6is X5 - The Work Horse
04 LSB M3 SOLD
7to3_enthusiast is offline   Reply With Quote
Old 10-15-2012, 11:41 AM   #24
E46inthe206
My Ride: 2003 BMW 330Ci
Originally Posted by dgreen78 View Post
Letr know when you're ready, I am putting one in my e46 right now and I'm also in Seattle.
Awesome! Definitely let me know how that turns out, maybe we could meet up at a meet sometime and I could take a look at it (as well as everyone else).
If it's not too much to ask, could you message me the details of your swap/expenses and where you're getting it done at? Just to sort of give me a ballpark after where I'd be power-wise after I spend a certain amount.
E46inthe206 is offline   Reply With Quote
Old 10-15-2012, 11:52 AM   #25
Sound Performance
Past Site Sponsor
Well here is the dyno sheet of a 2J on E85, 3.4L with both 6766 and 7275. If you can find a dyno sheet of the BMW motor with similar turbos we can compare power bands.
Old 10-15-2012, 12:15 PM   #26
7to3_enthusiast
I can see what I can find after work...I imagine from google search I'd pretty much just pull up HPF's charts...none of which run that high of boost I don't believe lol.
94 VR R2 Rx7 SOLD
04 LSB M3 SOLD
Old 10-15-2012, 12:26 PM   #27
E85head
My Ride: E46 M3
30 psi
Old 10-15-2012, 12:40 PM   #28
Sound Performance
Past Site Sponsor
Originally Posted by E85head View Post
That does not help as it is an 82 mm turbo!!
Here is the same turbo on a 2J !!
Old 10-15-2012, 01:51 PM   #29
str8dum1
My Ride: VQ38DETT
craigs car is a dyno standout for sure.
Engine control is very simple and straight forward on a 2JZ. The cams arent even being controlled in current E46s by the aftermarket ECUs. I gained 60-80whp just by changing my cam angles over stock, and that was just intake cams on a VQ. There is so much power being left on the table with current E46 tunes that do employ full vanos control with aftermarket cams
Def would love to see a E46 with a 5" fender cutout exhaust where the vent is now
VQ38DETT on twin 6262 with ProEFI128
str8dum1 is offline   Reply With Quote
Old 10-15-2012, 02:18 PM   #30
boostedisbetter
boostedisbetter's Avatar
My Ride: NiNe tHoUsAnD!!!
What I like best about this car is that there is literally NO smoke coming out of the back of the car. Well built and perfectly tuned! SICK
** Political sig removed **
boostedisbetter is offline   Reply With Quote
Old 10-15-2012, 02:20 PM   #31
str8dum1
My Ride: VQ38DETT
there is no smoke out the back because the exhaust exits in front of the passenger door.
Old 10-15-2012, 02:35 PM   #32
Sound Performance
Past Site Sponsor
There is no smoke coming out of the front either!!
Old 10-15-2012, 02:39 PM   #33
str8dum1
My Ride: VQ38DETT
alcohol FTW!
Old 10-15-2012, 03:00 PM   #34
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
FYI. AEM controls cams on s54 HPF turbo
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 10-15-2012, 03:07 PM   #35
FragNasty
My Ride: Car
The S54 runs at that BMW spec angle rather than straight up and down. That makes for some serious space restrictions on the exhaust side of the engine bay. I would bet 10 dollars that the the log style exhaust manifold that HPF uses is the bottleneck.
HPF has this recommendation that sleeved be used in their stage 4, however they had 1k whps being produced by a non-sleeved block if memory serves. Even with the extra boost pressure required to overcome the possible exhaust manifold restriction, it didn't seem to compromise the 0.020 over-bored setup they ran. So maybe sleeves are optional on an S54 setup targeting just over 1k whp. I may be wrong about this so feel free to chime in anyone.
Perhaps these manifold restrictions has been resolved in their drag setup, but the dyno readings through the TH400 auto doesn't really compare well to the 6spd, especially with that torque convertor. Does anyone know more about that?
PS, what angle is that S54 slanted at? Does anyone know for sure?
FragNasty is offline   Reply With Quote
Old 10-15-2012, 03:18 PM   #36
boostedisbetter
LOL NO, there is no smoke because it is tuned perfectly and there is no leakage of oil from ANY part of the motor build OR the turbo seals.
Old 10-15-2012, 03:36 PM   #37
being3
Modded ///Member
being3's Avatar
Don't forget if the car is off it doesn't smoke at all. Lol
Old 10-15-2012, 05:47 PM   #38
boostedisbetter
LOL, I hope your joking or you are missing the point along with the other guy lol. You hardly EVER see a dyno-tune where the car doesn't spit a little rich smoke. This thing is PERFECT!
Old 10-15-2012, 06:16 PM   #39
being3
Modded ///Member
being3's Avatar
I was joking for sure. even stock turbos have some smoke Great work on a nice build
Old 10-15-2012, 06:37 PM   #40
Sound Performance
Past Site Sponsor
Thanks guys!
