Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 10-12-2012, 06:38 PM   #1
paulbbelt
My Ride: 2004 330 CI
Fault codes P2240, P0171, and P0174
New member. I have an 04 330ci w/ 90k miles. Threw above codes. I replaced 02 sensors bfore cat. Code still there. Slight smell?? Any ideas?
Paul
PS foolish question....does car have to be off to reset code?
paulbbelt is offline   Reply With Quote
Old 10-12-2012, 06:47 PM   #2
jhaurimn
My Ride: 01' 330ci
Check for vacuum leaks in all vacuum hoses an especially the intake boots. If they look old you should just replace them. They are cheap. And no the car doesn't have to be off ... But then again my car is never on when I read codes
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 10-12-2012, 06:47 PM   #3
jhaurimn
My Ride: 01' 330ci
And the smell... Smell like oil?
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 10-12-2012, 07:58 PM   #4
a32axo
My Ride: 2004 bmw 330CI
Vcg or oil filter housing gasket, your lean codes are prolly disa and intake boots, the p2240 still haven't figured out. I have same car as you but with 80000 miles.
a32axo is offline   Reply With Quote
Old 10-13-2012, 09:08 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
+1 check your valve cover gasket. Simple DIY.
Old 10-14-2012, 05:49 AM   #6
paulbbelt
Read that it may be DME(?). Needs to be updated?
Old 10-14-2012, 05:49 AM   #7
paulbbelt
Read that DME (?) may have to be updated?
Old 10-15-2012, 06:25 PM   #8
a32axo
Yea I know I searched and people say dme update, just want to be 100% sure.
Old 10-15-2012, 06:36 PM   #9
BWOODM3
My Ride: 2002 M3 convertible
Let us know when you figure this out
BWOODM3 is offline   Reply With Quote
Old 10-15-2012, 08:26 PM   #10
777eThOd*
My Ride: spins too much
I've had P0171 and P0174 for a year lol, I've changed out so much Sh*t that I just stopped lol. I ordered a new MAF Sensor and that didn't get rid of it and I ordered a new Intake boot but I haven't installed it. Tell me How this goes, btw Welcome..
2007 BMW 335i FBO 6MT - Current
2013 Nissan Nismo 370Z - Current
2004 Non-M Facelift Coupe - SOLD
2006 BMW M3 - SOLD
777eThOd* is offline   Reply With Quote
Old 10-15-2012, 10:35 PM   #11
a32axo
Those codes I had also, bought intake boots and disa. Lean vides went away, I think it was disa valve!
Old 10-15-2012, 10:40 PM   #12
a32axo
P2240 p2237 still comes and goes, refers to oxygen sensors or dme update. I gen sensors are money for these years, $125 each. Dme update $80.
Old 10-15-2012, 10:41 PM   #13
777eThOd*
That's funny cause I was about to order a new DISA cause it's making a wierd rattling noise lol, then I can change out my intake boot aswell, thanks for the info.
2006 BMW M3 - SOLD
Old 10-15-2012, 11:07 PM   #14
a32axo
No problem man, here to help, that's what the forum is for, while your at it clean out your icv valve also.
Old 10-15-2012, 11:39 PM   #15
777eThOd*
Already did a while ago
2006 BMW M3 - SOLD
Old 10-16-2012, 12:00 AM   #16
a32axo
Now only if we can get some help on the other codes, a lot of forum mechanics here but no one seems to have the answers, lol.
Old 10-16-2012, 08:32 PM   #17
paulbbelt
New twist. Drove car 35 miles. (car has been idling rough) Went to lunch and at start up the low coolant indicator came on. I put approx 1pint in radiator after allowing 5 hrs to cool. Drove back 35 miles. towards end of drive, a "smell" was coming through ac vents. Got home and lifted hood. Smells like coolant. No easily recognizable leaks or mist.
Old 10-16-2012, 09:11 PM   #18
777eThOd*
Welcome to my world, where the CEL is always on 24/7 cause of P0171 and P0174 and the low coolant lights up every morning and sometimes afternoon. I'm already used to it lol..
2006 BMW M3 - SOLD
Old 10-16-2012, 09:19 PM   #19
a32axo
These cars are very sensitive!!!! Lol. At least it has me learning how to be a mechanic. Never touch under a good of a car before.
So far, change differential oil, coolant flush with thermostat change, expansion tank and hoses, intake boots, cleaned icv, replaced disa. Next is ofhg, spark plugs, vanos.
Display Modes
