Old 10-12-2012, 10:48 PM   #1
SH4DY
My Ride: '04 330Ci
330: low coolant temps?
This is the first fall/winter I've had my 04 330Ci and I've noticed some things that my 03 325i didn't do. It's been in the mid 40's here at night recently and while driving the needle on the coolant gauge won't get any higher than half way between the first graduation mark and straight up. It actually stays closer to the first mark if I maintain speeds of 50+ mph. If I'm in stop and go traffic it will eventually get to the middle (straight up) which had been the norm, but if I am able to maintain higher speeds it will drop down again.
Originally I had been worried that my MPG would be shot because I wasn't sure about how the fuel enrichment worked with these cars and the coolant temp but it doesn't really seem to effecting it that much.
In the last 6 months I've replaced the surge tank and cap with OEM units, replaced the water pump with a generic brand and installed an OE sized ECS tuning aluminum water pump pulley.
So, any thoughts? Is this typical? My motorcycles have exhibited this behavior but I've never had a car do this...
SH4DY is offline   Reply With Quote
Old 10-13-2012, 11:53 AM   #2
e46jki44
My Ride: e46 325i sedan
Thermostat could be stuck open. Do you have a check engine light? I get a cel that comes on once every few weeks and turns back off a few days later for coolant temp taking too long to get to operating temperature.
Sent from my SPH-D710 using Bimmer App
e46jki44 is offline   Reply With Quote
Old 10-13-2012, 04:56 PM   #3
SH4DY
My Ride: '04 330Ci
No cel. Warms up to the first mark pretty quickly. Heat definitely works inside car...
Sent from my PH44100 using Bimmer App
Old 10-13-2012, 05:38 PM   #4
aikmanson
My Ride: E30
Sounds like the thermostat to me. Do yourself a favor and put a new one in, you've done the rest of the cooling system anyways.
1990 BMW 325is - Stroker Build
2010 MINI Cooper S
1995 Saab 900 SE - JZW Stage 4
aikmanson is offline   Reply With Quote
