Old 10-15-2012, 08:02 AM   #21
bratliff
My Ride: 330i
Do your pullies and idlers as well. It's not a hard job and can be done with fairly basic hand tools. Read a DIY or two on the board to identify any tools you may need (torx bits most like). The hardest part of this IME is getting the new ET to sit securely on the bottom hoses. Everything else is a cake walk.
Originally Posted by LittleBear View Post
Thanks Folks,
I am looking at a rehab kit, including the rad, for $349. I think it is time (~108k) to do the hoses, ET, switches, etc since I'm in there. Throw in a metal impeller water pump because I don't know what's in there & it has ~ 35K on it... So that means a big fat kit. I'm not sure if I have the time & patience to do the work, so it may go to the shop.
Murf
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 10-15-2012, 08:10 AM   #22
Zell
Zell's Avatar
My Ride: so turbo wow
It's disappointing that the rads have the failure rate that they do. It's not exactly high, but I've found at 100k miles is when you'll find a leak if you will end up developing one. I do not know exactly where the leaks are, but it's really lame since it's such an expensive part relative to the rest of the simple cooling system components.
Why does the radiator leak when the AC condenser is directly in front of the bumper and gets pelted by rocks, bugs, and debris every single day at high-speed but never leaks?
Old 10-15-2012, 08:51 AM   #23
Stinger9
My Ride: '04 330Ci
Because you've got a metal to plastic connection with a rubber gasket in between.
Condenser is all metal and built more solid.
Every 100K for a new rad for $150 is just a fact of life.
Old 10-15-2012, 12:49 PM   #24
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Thanks Folks,
Murf
That sounds too cheap...but as long as it's an OE ET and therm(wahler) you should be fine. Radiator should be Behr.
Not sure what's in this kit...you have a link to it? I'm suspicious a little because of price...that's all.
A shop will cost you another $6-800 I'd guess, if not more.
You need about 4-5 hours...and you don't need too much patience...it's pretty straightforward if doing everything...and you've got back up here, you know!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-15-2012, 01:13 PM   #25
LittleBear
My Ride: 2001 330i
Link:
http://www.bavauto.com/shop.asp
I don't usually like BavAuto, but....
Murf
PS: looks like the link doesn't get you all the way to the kit. Go: "under hood", "cooling sys", then "radiators", second choice down is "Coolin Sys overhaul kit, standard Tranny" Pt#: "E46 Cool Manual".
"The Indian smiles, he thinks that the cowboy is his friend. The cowboy smiles, he is glad the Indian is fooled. Now he can exploit him"
LittleBear is offline   Reply With Quote
Old 10-15-2012, 01:36 PM   #26
limpiabota809
My Ride: 330 XI
Everything is there radiator is from nissens haven't heard much of that brand...if everything else holds water then it's a good deal I would assume
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 10-15-2012, 01:40 PM   #27
Stinger9
My Ride: '04 330Ci
LittleBear:
Doesn't source the ET, one of the most critical parts.
Nor hoses.
Also, perfect time to get brass bleeding screw.
Complete cooling system overhaul in a convenient kit! Includes the following components:
Radiator - Behr
Radiator Expansion Tank
Upper Radiator Hose
Lower Radiator Hose
Coolant Level Sending Unit
Expansion Tank Bleeder Screw
Water Pump & Gasket - With Upgraded Metal Impeller - Meyle
Thermostat & Gaskets - Wahler
Coolant Temperature Sensor
Please note: Manual Transmission
E46 COOL MANUAL
Cooling System Overhaul Kit - Standard Transmission
$ 349.95
Old 10-15-2012, 01:42 PM   #28
My Ride: Lexus
http://www.nissens.com/Supplier/quality_demands.htm
Seems fine to me if you got stuck w/ a Nissens. I haven't tried them though. I know lots of japanese cars that used nissens replacement radiators w/ good results
Old 10-15-2012, 01:42 PM   #29
dmax
dmax's Avatar
Bear,
The kit looks good...don't know the ET brand, but Bavauto should have that part right...wahler therm, Behr radiator. Meyle is a good name for some things...not sure of wp, but I bet it's just fine.
I'm surprised...good price.
Don't forget the OE coolant and distilled.
Belts and pulleys would be easy to get to know if you're predisposed to do a little more...otherwise, they're easy enough to get to later.
Return belts in the same direction they came off (mark them if reusing).
Mangofy your E46!
Old 10-18-2012, 12:15 PM   #30
limpiabota809
My Ride: 330 XI
I just changed my...Water pump
Water pump pulley
Idler pulley
Main belt
Ac belt
I noticed that my radiator is nissens and is stamped 2011 meaning I didn't have to change it ...but overall nissen doesn't seem like a bad brand/quality
Old 10-18-2012, 12:21 PM   #31
Stinger9
My Ride: '04 330Ci
Hoses are current?
Old 10-18-2012, 01:06 PM   #32
limpiabota809
My Ride: 330 XI
^ yes when I changed the ET and therm I took care of hoses...
