Old 10-13-2012, 02:15 PM   #1
farukh
My Ride: BMW 325i 2002
Help! What is this part?
Well, it's leaking oil :/ I did a temporary fix with gasket maker (not sure if its a good idea).
My valve cover is also leaking... I ordered a new one already...
I dont know, it all started after my vanos seal replacement. I guess it was time to change the valve cover, because it started to chip when I tried to clean it.
But I can't figure out what part is that circled red
farukh is offline   Reply With Quote
Old 10-13-2012, 02:20 PM   #2
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
pretty sure that's the oil line to vanos, did you use a new crush washer? tq it correctly?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 10-13-2012, 02:24 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Lol, that's the vanos oil line. Replace the crush washers.
Old 10-13-2012, 02:27 PM   #4
wasp9166
at first i was like, did this guy spill a slushy or something? then a read the thread......................lol
Old 10-13-2012, 02:31 PM   #5
farukh
lmao I know it looks stupid! But that damn thing leaks A LOT!
Old 10-13-2012, 02:32 PM   #6
farukh
Anyone knows the part number by any chance?
Old 10-13-2012, 02:34 PM   #7
farukh
http://www.pelicanparts.com/cgi-bin/...Conv%2C%20Each
That's what I found! Is it the thing that I need to replace?
Old 10-13-2012, 02:55 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
You don't need the entire hose, just the washers.
http://realoem.com/bmw/showparts.do?...70&hg=11&fg=15
Part number 32411093596 x2
Valve cover gasket
http://realoem.com/bmw/showparts.do?...72&hg=11&fg=15
Part number 11129070990 x1 and grommets 11121437395 x15
Old 10-13-2012, 02:57 PM   #9
farukh
Valve cover gasket
Really? Just washers? Nice! Alright, thanks for part numbers!
And unfortunately I need to change the whole valve cover :/
Old 10-13-2012, 02:59 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
Valve cover is cracked? Sorry to hear.
For the washers, you just need an adjustable wrench and you can loosen the hose from the top. Just make sure to put a rag under it since a good amount of oil will come out.
Old 10-13-2012, 03:35 PM   #11
farukh
How exactly is correct tq? Please let me know so that I don't mess up the new one!
Old 10-13-2012, 03:36 PM   #12
farukh
Yea :/ I started cleaning it when I was replacing my vcg, and it just started chipping into pieces!
Old 10-13-2012, 03:45 PM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
I just tightened it hand tight with a ratchet and gave it a quarter turn more.
Old 10-13-2012, 03:52 PM   #14
wasp9166
24 ft lbs or 32 newton meters
did you do the vanos job? if you did, you should really have the whole procedure mapped out in your head including tq values of everything before you begin
if you didn't , bring it back and ask why they reused the washers, and if they say they didn't, ask em what the bolt was tqed to
Old 10-13-2012, 04:51 PM   #15
farukh
Yea, I did it myself! In fact, I even think that I had a new washer... But it was an all night project and by like 6 am, I couldn't think straight lol Hmmm, I gotta see if I still have that new washer somewhere!
Old 10-13-2012, 07:04 PM   #16
Mcbridges11
My Ride: 03 325i, 03 540i
youll actually need 2 washers- one for the inside (vanos side) one for the bolt head side-
Mcbridges11 is offline   Reply With Quote
Old 10-13-2012, 07:06 PM   #17
wasp9166
been a while so i can't confirm or deny this, but the realoem pic doesn't show it that way, but it does make sense
Old 10-13-2012, 07:08 PM   #18
Mcbridges11
ya i was looking at that too- just did my vanos seals 3 days ago- often one stays stuck to the line-- be sure to clean all that lea stuff off of the line as well as the VCG so you dont run into more seal issues
Old 10-13-2012, 07:27 PM   #19
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
I recommend replacing the line as well as the washers. The line will eventually leak where the rubber meets the metal ends. It's not really that expensive and will look nice once it's done.
Old 10-13-2012, 07:31 PM   #20
InDiGlOM3
My Ride: HPF M3 stg 2.5
Valve cover gasket
How do you know he needs just the washer? Ive never seen crush washers go bad unless messed with....ive seen the line crack at the banjo however.
just read rest of his post lol, might be crush washers but ive reused these before and it was fine, cant say its ONLY crush washers from the pic.
