Sponsored by BimmerWorld
Old 10-13-2012, 05:21 PM   #1
Gepetto
My Ride: 2004 325i
Strange noise from rear shocks
Hi everybody,
In August, I had my struts and shocks replaced. I purchased the parts myself (Bilstein HD set from tunermotorsport.com, with spring pads and shock mounts). Ever since I had them installed, when going over bumps the back makes a sort of clunking noise that it never made before. The handling is improved, and accelerating/braking/turning are fine (no noise). Just going over bumps. Is it crappy shock mounts that came with the kit? If so, can these be easily changed to stock BMW mounts?
Gepetto is offline   Reply With Quote
Old 10-15-2012, 10:23 AM   #2
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
What is the condition of your rear sway bar end links? Have your RTABs been replaced yet? What kind of mileage do you have on the car?
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 10-15-2012, 11:56 AM   #3
Gepetto
My Ride: 2004 325i
I don't know the condition of the rear sway bar links. The RTAB, to my knowledge, are the originals. When I had the work done, I told the guys to take care of anything that was worn out and they didn't mention anything.
Before I changed the shocks, though, everything was normal (except I could tell they were worn out by the ride).
How much do the sway bar links and RTAB's cost?
Old 10-23-2012, 12:29 AM   #4
J LAU
My Ride: E46 / E82 / E89
I have the same issue. I start hearing clunking noise after I got new suspensions.
Noise only occurs under 30mph on light-heavy bumpy surfaces.
I just got a set of UUC RTAB for below $65. Will have them installed next week.
FYI, I changed the RSMs but clunking noise remains. I know one of my Rear Sway bar links is slightly bent since years ago, but I never bothered to change them. I will do the RTABs first and let you know the result. And These bushings including Subframe bushings are not easy to inspect unless you actually take them apart, then you might see some cracks on them.
J LAU is offline   Reply With Quote
Old 11-06-2012, 12:13 AM   #5
J LAU
I just had the UUC RTABs installed last night. The clunking noise is still there.
But the RTABs did make a different in handling.
I might try to tighten all the bolts under the car and see what's up.
I suspect its the differential bushing that is bad. =/
Old 11-06-2012, 12:19 AM   #6
Gepetto
My Ride: 2004 325i
Is it a dramatic difference in handling? I may try to tighten everything too. I don't think it's the differential though (at least not with me)...it's just on larger bumps I hear a clunk.
Old 11-06-2012, 01:09 AM   #7
euG!
My Ride: ZHP SALOON
Send a message via AIM to euG!
I have the same problem. I uninstalled and reinstalled the rear struts, tightened rear sway links and still have clunking. Is it possible that bad subframe bushings could cause the clunking?
'04 330i ZHP
TiAg/Alcantara
3.46/APEX/KONI/COBY/JAFFSTER
euG! is offline   Reply With Quote
Old 11-06-2012, 01:48 AM   #8
J LAU
I felt the different with the new RTABs when i went on twisty roads.
But I think the car got bumpier on uneven surfaces.
I might tighten all the bolts on the bushings to try.
Beside the RTABs, I also changed the Rear sway bar links and the clunking noise is still there.
Old 11-06-2012, 01:48 AM   #9
J LAU
euG! I see that you are in LA. would you like to meet up and see if we have the same problem?
Old 11-06-2012, 10:41 AM   #10
euG!
My Ride: ZHP SALOON
Pm'd
'04 330i ZHP
TiAg/Alcantara
Old 11-08-2012, 12:00 PM   #11
euG!
My Ride: ZHP SALOON
for updates
'04 330i ZHP
TiAg/Alcantara
