Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 10-15-2012, 04:55 PM   #1
Hockeyman17
My Ride: 2005 E46 M3 SMG
How do I fix this??
I put my garbage on the floor for a few mins before I took it out and something leaked into the laminate. Any way I can leech it out without replacing the boards?
Hockeyman17 is offline   Reply With Quote
Old 10-15-2012, 04:57 PM   #2
Hockeyman17
Oops
Old 10-15-2012, 05:03 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
What the something was would make a difference.
If it's water soluble, you might try lightly wetting it in hopes it dilutes it and allows the stain to soak deeper below the surface.
You might try a dilute solution of an oxygen bleach...which would be safer than chlorine bleach.
You might try a laundry stain remover that works with enzymes...forget the name of the stuff.
Much of that will probably look better when it dries (I'm assuming it's still wet), but I think I'd work up.
You have an exit strategy if needed, so good luck with my guesses!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-15-2012, 07:26 PM   #4
330iPilot
My Ride: Titanium Silver 330i
Try a rug.
330iPilot is offline   Reply With Quote
Old 10-18-2012, 11:40 AM   #5
BB BMW
My Ride: 04 330ci ZHP
Try soaking up as much liquid as possible. If it is not oil base, try putting a damp towel on top for a while, then use a fan or hair dryer to dry out.
Last resort, pull it up and replace with any left over peices you may have.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
Thomas Jefferson
BB BMW is offline   Reply With Quote
