Aftermarket head unit and subs install question
I'm planning to get an aftermarket head unit to install into my 330ci (which has the HK system) along with a new amp and some 10" subwoofers but had a question. Since I plan on keeping the main HK amplifier and the 10 stock speakers it drives (that is, I'm just getting rid of the small HK sub amp and the 6x9 subwoofers), do I still use the method of tapping into the main amp's inputs to run the aftermarket amp (as has been mentioned in previous posts about adding an aftermarket amp and subs to the HK system) or do I run the amp and subs using the new head unit's RCA sub-outs as is standard with most aftermarket installs? Thanks.
