Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#21 |
Ceiling missing!
took me 1 hour for both sides with the harbor freight tool. look it up.
#22 | ||
#23 |
Ceiling missing!
I dont see how I wasted time, it took 1 hour to the entire job. Takes 5 minutes to push it out with the harbor freight tool.
#24 | |
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
How is that PA soft scanner working for ya?
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle |
#25 |
#26 |
Is the rear lower control arm replacement essentially the same concept in M cars as well? Where can I get this bushing tool at?
#27 | |
as for the RTAB job, ya.. now being familiar with the method that works without the actual tool, I can do both side in probably 3 hours. And I was able to place the bracket in the old position keeping the right original alignment. Sent from my SGH-I727R using Bimmer App |
#28 |
Ceiling missing!
Oh didn't sense the Internet sarcasm lol. And yes it's a similar concept to the M trailing arm, only thin really different is sometimes the bushing will have a flange which can cause a problem sometimes. I've only seen that style of bushing once though. Other then that it's pretty much the same thing.
#29 |
My Ride: '04 330Ci '06 GS500F
Pawel, I made one of these tools for myself (dad has machine shop). If you need to borrow it, let me know.
#30 |
^ ill keep that in mind if i need to do it again.. your not too far away either.. thanks!
#31 |
#32 |
Weagle Weagle
#33 |
Ceiling missing!
If you searched you would have discovered the DIY and knew what tool I was talking about.
#34 |
Weagle Weagle
#35 |
Weagle Weagle
Okay, I found it because I am an internet god.
Ball Joint tool http://www.harborfreight.com/ball-jo...cles-4065.html |
#36 |
Ceiling missing!
And you could have searched for him
And found the answer.
#37 |
Weagle Weagle
