E46 Convertible
Old 10-16-2012, 02:26 PM   #1
powersro
My Ride: 2002 325 ci
Simple Problem, need springs, part number..
Hi,
I have a simple problem and hopefully a simple fix. I just pick up a used 2002 325ci and the two small retractable plastic pieces that are just in front of the top lid are missing the springs that pull them back into position. Make sense? Anyone know the part number of these spring and where I could buy them.
Thx,
Bob
powersro is offline   Reply With Quote
Old 10-16-2012, 07:31 PM   #2
wildirish317
My Ride: 2004 325Ci vert
51437147719 and 51437147720 for left and right, respectively. Good prices at www.thebmwpartstore.com, but they are only $8 each retail.
Go to www.realoem.com to find parts in the future.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 10-16-2012, 08:02 PM   #3
fmzip
My Ride: '08 328xi / '01 530i
I'd double check those part numbers. The spring and rod assembly changed. Early model convertibles are different.
There should be a plastic rod as well that sits inside the spring. You likely need items 13 and 14. The spring and rods are identical on both sides in pre 2003 convertibles:
51438163692 Spring
51437029018 Rod
http://www.realoem.com/bmw/showparts...87&hg=51&fg=50
fmzip is offline   Reply With Quote
Old 10-16-2012, 08:14 PM   #4
wildirish317
Thanks for the catch. I automatically search realoem for my car, which is a 2004.
Old 10-16-2012, 08:26 PM   #5
fmzip
^^^^that whole assembly changed in 2003 including the sliding cover and piece it sits in.
ask me how I know
Old 10-18-2012, 12:39 AM   #6
cityjohn
My Ride: 2001 M3
My brackets broke so the springs pull out. Just rigged up a rubber band with a zip tie and it works fine.
cityjohn is offline   Reply With Quote
Old 10-18-2012, 05:41 AM   #7
powersro
Thanks for all the help, guys. Found the parts and have them on order. See, I told you it was simple, with a little help
Bob
Old 10-19-2012, 03:37 PM   #8
ECSTuning
ECSTuning's Avatar
My Ride: BMW
51438163692 Spring
51437029018 Rod
Below are some photos for reference
51437029018
51438163692
Old 10-19-2012, 03:39 PM   #9
fmzip
^^^ nice pics!
Remember, these are for pre 2003 everyone!
Old 10-31-2012, 01:24 PM   #10
jdberger
My Ride: 2005 330cic
The part numbers for a 2005 are
51437147719
51437147720
jdberger is offline   Reply With Quote
Old 10-31-2012, 01:31 PM   #11
ECSTuning
ECSTuning's Avatar
My Ride: BMW
^photos of above parts for reference
51437147720 click image for more information
51437147719 click image for more information
Old 10-31-2012, 03:27 PM   #12
jdberger
Thanks - it took me something like 3 days to find those. I was looking in the Convertible Top instead of the Door sections of the parts diagrams.
Are they easy to install? I haven't had much of a chance to get under the cover with a flashlight.
Old 10-31-2012, 08:27 PM   #13
fmzip
They can be installed easily with the top down on a pre 2003
If your slider is broken (where my thumb is attached) you will need to remove the back seat and take the side panels off to get a new slider installed. And yes, the sliders are different for pre 2003's as well.
Old 11-01-2012, 12:02 AM   #14
jdberger
grrr..
alright. It's $20. I'm buying them and I'll document the repair. I'm relatively handy. I changed out a light switch once. . . .
Old 11-06-2012, 11:12 AM   #15
dtsurfcat
My Ride: 02 325i
JDberger - how did this go?
JD - I have the same issue except both of mine are missing. So I don't have a good one to reference. Please let me know if you are going to document the process so I can see what it's supposed to look like.
dtsurfcat
Originally Posted by jdberger View Post
grrr..
dtsurfcat is offline   Reply With Quote
Old 11-14-2012, 02:47 PM   #16
jdberger
Shipping from ECS was amazingly slow. I guess I'm just used to Amazon.
I'll to the repair Sunday. I'll take pictures.
Assuming I'm able to put everything back together without any extra parts remaining, I'll post the pics that night.
Old 11-22-2012, 12:02 AM   #17
jdberger
I gave it a shot on Sunday, but I was stumped. I guess I'll have to follow instructions.
http://tis.spaghetticoder.org/s/view.pl?1/05/95/90
