Old 10-16-2012, 08:12 PM   #1
My Ride: Lexus
The best way to lift your E46 using a jack and jackstands
This is a tutorial on how to lift your E46 safely and securely. Never perform any work or lift your vehicle without reading your vehicle's owner's manual first. Always use quality jacks, jackstands, and other miscellaneous equipment and ensure it is in fully functioning order before proceeding.
Always follow the directions of the manufacturer of the equipment you are using.
Follow these directions at your own discretion according to your comfort and/or skill level.
I am not responsible for any damages to people or property.
Warning: Jacks should only be used to lift a vehicle, not support it for any extended amount of time. Never get under a vehicle supported by only a jack.
For extra security, place your wheels under rigid body sections of the vehicle.
Always work on level ground.
Okay so basically if your E46 has a front reinforcement plate as follows:
You can follow my method of supporting the vehicle safely on four jackstands and a high quality low-profile jack. I got mine from Harbor Freight.
The picture explains it all, but basically you are lifting the side-rear high enough to get a jackstand under the front-side jackpad you are lifting. Repeat on the other side. Then lift the vehicle by the rear subframe (never the aluminum support) and then place jackstands under the rear-side jack pads.
You will then have a jackstand under each jacking point. Lowering the car is reversed process.
The following photo is of an E46 M3 convertible. Same concept applies to this photo for your non-M cars.
E46 M3s and earlier non-Ms have a front-central jacking point on the front subframe reinforcement. That can be used in a similar manner as the rear subframe lift point.
Good luck and again, use common sense and safety!
To clarify: USE JACKPADS AND REAR SUBFRAME TO LIFT VEHICLE ONLY. DO NOT USE "FRAME RAILS," OR THE FRONT ALUMINUM REINFORCEMENT PLATE FOR NON-M VEHICLES. THE JACKPAD LIFT POINTS ARE REINFORCED PARTICULARLY FOR LIFTING. I RECOMMEND TO HAVE A FRIEND WATCH THE JACKSTAND AS YOU LOWER THE VEHICLE BACK DOWN TO ENSURE IT DOESN'T SLIDE OFF.
Old 10-16-2012, 08:32 PM   #2
choxor
My Ride: JDM
Well done, sir.
Old 10-16-2012, 08:35 PM   #3
calialx1
My Ride: FL 330i, 3000GT
I stopped reading after high quality jack from harbor freight.....
Sent from my C771 using Bimmer App
calialx1 is offline   Reply With Quote
Old 10-16-2012, 08:52 PM   #4
Zell
Zell's Avatar
My Ride: so turbo wow
Thank you. I will give this a try this weekend just to test it out.
Old 10-16-2012, 09:10 PM   #5
Saintluk2
My Ride: 2000 323i sedan
I don't know much about the quality of Harbor Freight. calialx1 what's your take on it ?
Saintluk2 is offline   Reply With Quote
Old 10-16-2012, 09:16 PM   #6
My Ride: Lexus
My friend's has had his HF aluminum jack for around 10 years and it's been through heavy use. Done a few engine/trans swaps. I've had mine for three years. It's been a trooper. What low profile jacks would you recommend that's decently priced? Jacks are only used for lifting, so not sure why it has to be from Snap-On, unless you're a mechanic for a living.
Old 10-16-2012, 09:25 PM   #7
choxor
My Ride: JDM
I've had the aluminum HF jack for years and it's worked fine
Old 10-16-2012, 09:25 PM   #8
ANREC330
My Ride: C6 Vette & M3
I've had a low profile jack from Harbor Freight for 5 years using it for lifting 6 different cars from my e46 to my parents Denali XL. I've never had one problem with it.
ANREC330 is offline   Reply With Quote
Old 10-16-2012, 10:26 PM   #9
lcoleman
My Ride: '79 Massey Ferguson
HF jacks are fine; the pre-Rapid-Pump models are better, though. I think you can still get that one at Northern.
I do disagree with this method of jacking the car up, as outlined in the other thread. Much safer to use the front jack point than to jack one side at a time, imo.
Old 10-17-2012, 07:10 AM   #10
yetieater
My Ride: '03 330i
Might be that modified suspension setups won't allow the HF jack to clear the front bumper. I know that I have enough trouble accessing the front jacking point on my vehicle.
bulletproof one piece at a time
full listing of BMW Performance parts for the E46
yetieater is offline   Reply With Quote
Old 10-17-2012, 11:17 AM   #11
Jesse M
My Ride: 05' ZHP
I have the lowest profile jack from HF and it's still not low enough, I have to have a buddy pull up on a fender half an inch to slide her under there.
Jesse M is offline   Reply With Quote
Old 10-17-2012, 09:06 PM   #12
Starless
My Ride: 02' 325i
The only problem with the method in the original post is that you can only jack the car up that high. I like to lift the car as high as (safely) possible on the jack stands for major work. So, to put the front on the jack stands I have to use either the "button" of the reinforcement plate or the "frame rails". Mostly the "button"...
And HF low profile jack is great! 23" (height range!)
But I think the above method will work fine for putting the car on the jack stands on their lowest setting.
Starless is offline   Reply With Quote
Old 10-17-2012, 09:37 PM   #13
jennifhanlon
Banned
Send a message via ICQ to jennifhanlon
jennifhanlon is offline   Reply With Quote
Old 10-17-2012, 10:23 PM   #14
Grande D
My Ride: E36 M3
Nice post!
But since we must always bicker (!), poor taste in tires on the pictured car!
It will change your life!
Old 10-17-2012, 10:29 PM   #15
Zell
Zell's Avatar
I can't tell exactly what tires those are, but they look like Continental ExtremeContact DW's. Those are well-rated
Old 10-17-2012, 11:53 PM   #16
killj0y
My Ride: 2000 323i
Lol I've seen plenty of reputable shops use HF jacks, I'm gonna get one, and it won't see near the abuse. The idea is to have it lift temporarily while you position jack stands....I don't trust any jack with me under it no matter the brand. Besides generally a jack either works or it doesn't.
killj0y is offline   Reply With Quote
Old 10-18-2012, 01:14 AM   #17
tock172
My Ride: '12 135i DCT
Your loss.
Excellent post. When I first joined here, it took me a long time to find the same information. Thanks for doing the community this service.
As for the jack, I have the 1.5 ton lightweight aluminum jack from harbor freight and I love it. It's light, low profile and raises my car quickly. It even looks good. I threw down $70 or so for it and I even got the extended warranty. I also have the matching aluminum jackstands and they're great too. Incredibly lightweight as well. I can put my jack, jackstands, air compressor and a ton of other tools in my trunk with no worries.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 10-21-2012, 09:27 PM   #18
jbehr99
My Ride: 2005 330CI Vert ZHP
I agree with Mango that you should only lift the car from those 5 points he listed, but I do have a question. When you lift the car up from the rear using a floor jack at one of the side factory jacking points so you can place a jack stand under one of the front side jacking points, I'm assuming you have to jack the car up pretty high for this? Will there be enough clearance to place a jack stand under the front side jack point and be able to get the car off the ground a reasonable amount with placing the front jack stand?
jbehr99 is offline   Reply With Quote
Old 10-21-2012, 10:50 PM   #19
rcsummers
My Ride: M3
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 10-22-2012, 12:53 AM   #20
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Why can't we use the frame rails to lift the car?
