Old 10-17-2012, 01:47 PM   #1
STORMER
My Ride: AA SC 98 M3
HG need replaced?
I hope to be taking posession of a 99 e36 m with a stage 2 aa kit. Its a bit of a broad question so I thought Id ask here.
The car has 215,000 kms well maintained. Kit has been on 40,000 kms or so. No leaks in car except vcg is weeping and no boost leaks. New m5 clutch and lightweight flywheel. Tranny is solid and compression checks are good!
So my question is should I do the hg preventative? Is it necessary? Only running 10psi. Also what else should I expect to do in the near future? Supercharger maintenance? Etc? TIA
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 10-17-2012, 03:05 PM   #2
STORMER
:crickets:
360+rwhp
Old 10-17-2012, 03:51 PM   #3
A4RingedONE8T
My Ride: Turbo ///M Roadster
If compression and leakdown are good, no milkshake on the oil cap or in the coolant bottle, boost on! What made you question whether to replace it or not?
A4RingedONE8T is offline   Reply With Quote
Old 10-17-2012, 04:06 PM   #4
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Your best bet for this answer would be to head over to Bimmerforums.com
MSpired is offline   Reply With Quote
Old 10-17-2012, 05:31 PM   #5
STORMER
Jus thinking because it has higher kms and is boosted that there may be a threat of the hg being on its way out.
360+rwhp
Old 10-17-2012, 05:37 PM   #6
MaverickM3
My Ride: gets badge
If your compression and leak down test are good then your engine is fine. Go have fun with it.
MaverickM3 is offline   Reply With Quote
Old 10-18-2012, 08:03 AM   #7
A4RingedONE8T
Because I didn't already answer his question? Just because most FI cars on here are E46 M3's doesn't mean we all have those cars. Quite a few people here with plenty of experience with boosted BMW's in general
Old 10-18-2012, 08:43 AM   #8
STORMER
Worth noting I have never owned FI before so just curious what to look for and what to expect when owning a unit with higher kms
360+rwhp
Old 10-18-2012, 09:39 AM   #9
Zak@ActiveAutowerke
Past Site Sponsor
My Ride: '94 325is
Drive it had and check the top coolant hose. If it's not like a rock after a 30 minute beating you're good.
Changing a headgasket isn't really a preventative thing. If it ain't broke don't fix it!
Zak@ActiveAutowerke is offline   Reply With Quote
Old 10-18-2012, 10:31 AM   #10
STORMER
Originally Posted by Zak@ActiveAutowerke View Post
Drive it hard and check the top coolant hose. If it's not like a rock after a 30 minute beating you're good.
Thanks for chiming in! Could you explain a little further? Why would it be like a rock?
Also anythin you could mention to look for or be prepared to address with a higher km car and a charger with 40,000 kms?
360+rwhp
Old 10-18-2012, 11:03 AM   #11
A4RingedONE8T
If the headgasket has a leak between a cylinder and a coolant passage, combustion will over pressurize the coolant system. In this case you would be inducing air (combustion) into the coolant. Air rises so it would be found/trapped in the highest point of the cooling system.
Old 10-18-2012, 12:38 PM   #12
MSpired
Of course you did! Just pointing him to where the majority of the e36 crowd resides in order to get more diverse answers in the future
Old 10-18-2012, 01:28 PM   #13
A4RingedONE8T
A 99' 323 is an E46
Old 10-18-2012, 02:49 PM   #14
MSpired
A 99' 323 is an E46
Old 10-18-2012, 03:09 PM   #15
STORMER
Ya I definately plan on heading over to the other forums. But i just love everybody here too much lol. It is a general question concerning fi and have gotten some good response thanks!
Still is there any further things to be aware of fi related that maybe I should look for or be aware of? Thanks!
360+rwhp
Old 10-18-2012, 03:15 PM   #16
A4RingedONE8T
Didn't catch that, sorry!
Old 10-18-2012, 03:16 PM   #17
A4RingedONE8T
Yes, a supercharged S52 is still slow
Old 10-18-2012, 03:18 PM   #18
Zak@ActiveAutowerke
Past Site Sponsor
My Ride: '94 325is
While being quite reliable, a supercharger will exacerbate any current issues and could accelerate wear in some areas. As long as you keep up with everything on time you should be fine. Just make sure you're up on your oil changes, change your Rotrex oil after about 80k, change the plugs every 15-20k miles. As long as you stay on top of maintenance you shouldn't have a problem.
Old 10-18-2012, 03:34 PM   #19
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Zak,
Sorry to go off topic - is the HKS charger the same in Oil change? 80,000 KM?
AMG-ETR is offline   Reply With Quote
Old 10-18-2012, 04:09 PM   #20
STORMER
Really?
This thing is putting down 360-380 to the wheels.
360+rwhp
