Sponsored by BimmerWorld
Old 10-17-2012, 05:36 PM   #1
darksideracer69
My Ride: 01 325ci
camber plates
Which camber plates allow for the most adjustment? The cosmos camber plates say the allow for -3 and +4 change, which is a lot more range than the spc ones i currently have.
Input guys
IMAG02051
Old 10-17-2012, 05:59 PM   #2
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Well the + part is relatively irrelevant for most as you don't want positive camber, you want negative camber. The Vorshlag camber plates allow you to go -3.5 which is nice (they say 0.0 to -3.5).
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 10-18-2012, 12:38 PM   #3
JRMcDaniel
My Ride: Racecars
It depends.
You should not be asking what the camber range is. You should be asking what the usable slot range is. The camber is affected by factors other than just the camber plate. And most camber plates are actually limited by the size of the strut top nut and the edge of the strut tower. Are you really looking for full range or are you looking for max camber? The Vorshlag plates will go from slightly positive to all-available negative considering the strut top nut will contact the tower edge.
JRMcDaniel is offline   Reply With Quote
