Old 10-17-2012, 10:43 PM   #1
The last emperor
My Ride: 03 BMW e46
Abs, brake and traction control lights came on
What could have caused this? What's the problem and how can I fix it? Should I still drive the car on the hwy or is it dangerous?
Respect all, Fear none
The last emperor is offline   Reply With Quote
Old 10-18-2012, 12:21 AM   #2
afstud
My Ride: 2003 ZHP 6-speed
Search its probably one of your front abs sensors that's mounts to the wheel hub assembly, I had this issue a few weeks back, if those lights are on and your speedo doesn't work then its a rear abs sensor
2003 330i ZHP 6 speed
afstud is offline   Reply With Quote
Old 10-22-2012, 05:43 PM   #3
TheJonRoss
My Ride: 2002 325xi, 2005 X5
That will sometimes happen after you've disconnected your battery. It will go away after a few minutes of driving. But your case may be different.
-Jon
BMWCCA# 473325
Join the Experience
TheJonRoss is offline   Reply With Quote
Old 10-25-2012, 02:44 PM   #4
Mike666
My Ride: 2000 323i
Wheel Speed sensor has gone bad - happened to me.
Mike666 is offline   Reply With Quote
Old 10-25-2012, 02:50 PM   #5
Custom3
My Ride: HellRot 330CI
that sensor isnt cheap either ......smh
Old 10-25-2012, 02:51 PM   #6
The last emperor
My Ride: 03 BMW e46
They turned off after a while but I should replace it anyways
Old 10-25-2012, 05:09 PM   #7
shahbaz99
My Ride: Clean 330ci
wheel speed sensor. try cleaning it first, theres diy out there for it. I cleaned mine up and haven't had the lights since.
shahbaz99 is offline   Reply With Quote
Old 10-26-2012, 11:05 AM   #8
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
Do this,
Turn your car on, but not the engine. turn on your stereo. LOUD. Flash your headlights. if the stereo shuts off or headlights are dim, its just your battery. you just need to charge it.
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
